DD 2006 C2S Deep Blue Wetness and Swissvax
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Nov 6, 2007.
  1. detailersdomain
    This was a treat a 2006 Lapis Blue C2S. This was a full detail. (sorry no interior shots forgot to take them) The car was in good shape but as you will see there are swirls and imperfections. Interior was in great shape need a nice vacuum, leather cleaning/conditioning and wipe down.
    Products Used:
    Adam's Car Wash
    Adam's Clay Bar with Adam's Detail Spray as lube
    Adam's VRT
    Adam's Glass Cleaner
    Adam's Undercarriage
    Adam's Metal 1 and Metal 2
    P21S Wheel Cleaner Gel
    P21S Autowash
    Menzerna 106FA
    Swissvax Cleaner Fluid
    Swissvax Concorso
    Einszett Leathercare
    Einszett Cockpit
    Einszett Detail Spray
    Tools:
    3m Sun Gun
    Brinkman Xenon Portable
    Metabo 12-175
    Tons of towels
    Procedure:
    Exterior:
    1. Rinsed down the wheels (they were cool enough to touch)
    2. Sprayed down the wheels with some P21S Wheel Cleaner
    3. Sprayed down the wheel wells and tires with P21S Autowash
    3. Brush and cleaned the wheels and tires with a Boar's Hair Brush
    4. Rinsed down the wheels, tires, and wheel wells
    5. Rinse the car down
    6. Used the foamgun (Adam's Car Wash) to apply soap, let it sit and then
    7. Used the Shmitt to wash the car, from top to hood to sides to rear.
    8. Rinse car off throughly
    9. Spritz some Adam's Detail Spray on the car and dried off the car.
    10. Brought the car in and proceeded to clay the car using Adam's Clay Bar and Detail Spray
    11. Used the Metabo with the Menzerna 106fa to polish out all the minor imperfections. (blue pad) a few passes per panel at 1500 rpm (Metabo rotary)
    12. After each section was corrected I buffed off the excess polish with a MF Buffing Towel.
    13. Applied Swissvax Cleaner Fluid and removed with MF Towel (removed after you apply in small sections, you don't want this to dray up)
    14. Applied Swissvax Concorso by hand and let sit for about 10-13 minutes, buffed off to a nice wet and deep shine with a MF Towel
    15. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior)
    16. Dressed the tires with Adam's VRT
    17. Dressed wheel wells with Adam's Undercarriage Spray
    18. Used Adam's Detail Spray to do a final wipe down on the wheels.
    19. Used the 1Z Detail Spray for a final wipe down and inspected the car.
    20. Polished up the tips with Adam's Metal 1 and Metal 2.
    Interior:
    Vacuumed the Trunk, Dressed the covers in the trunk area.
    Vacuumed the Interior
    Cleaned and conditioned the Leather treated with Einszett Leathercare
    Wiped down the interior (not the leather areas) with Einszett Cockpit
    Wiped down the door jambs with Adam's Detail Spray
    Cleaned Windows
    Now some pics:
    Before:
    After wash:
    Hood before:
    Hood after wash:
    Hood after:
    Swissvax Concorso being applied!
    Tips before:
    Tips after:
    Trunk after:
  2. P1et
    Phil, I don't know how you do it, but with a warehouse full of goodies, well, maybe I do know!
  3. detailersdomain
    Now some pics:
    After inside:
    After outside:
    The end [:D]
  4. P1et
    Phil, want to post some pics up of your Audi? In every single photoshoot she lurks in the background!
  5. Calgarydetail
    your work is always stunning, this is no exception
  6. FMINUS
    FMINUS DB Pro Supporter
    Very Nice!!!
  7. klumzypinoy
    klumzypinoy Nuba Guru
    IMO this is the best Porsche detail I've seen from you!
  8. supercharged
    beautiful color, beautiful job! Must be a great wax and a great detailer!
