Cobra paint correction
Discussion in 'Show and Shine' started by mixxer, Sep 1, 2008.
  1. mixxer
    mixxer Birth of a Detailer
    This was by far the worst paint correction ive had to deal with. This was paint correction and wax only.It came out pretty good , i wet sanded some areas but some of the stuff was just to deep to remove and there were rids everywhere.I wasnt pleased with hood but there was some body and paint work on the hood and there was some grinder marks on the hood i just could not remove after compounding multiple times ,it wouldhave needed a full wet sand and time and budget just did not allow for it as i spend 3-4 more hours polishing than was budgeted for any way just because i wasnt satisfied.
    First i washed car with ONR and taped trim.
    Before i started the PDR guy to remove 8 dings from car.
    Polishing process - 16 hours with flex and alot of pad combos both wool and foam.
    Being that the car was black i decided on a 3 stage polish process using
    (1)megs 105 compound and 3m ultra cut compound- 2 of the heaveiest hitters there are.
    (2) Menzerna SIP and prima swirl[was testing cut of both]
    (3) mezerna 106 with lite cut/finish pad.
    I peformed IPA wipe down and used Infratech cm 5300 color matching light after each pass to check work, there were multiple areas i had to add extra passes.
    After polishing was complete I washed car with foam gun and two buckets.
    Did entire car glass,plastics and trim with VMG.
    Dressed tires with megs hot shine gel[ a sample i had gotten to try]
    Then used Nattys blue for LSP.
    Total time about 19 hours.
    Thanks for looking!
    Some befores afters and 50/50
    before after 50/50
    other side of 50/50
  2. 911Fanatic
    Fantastic turnaround! Did you take away the garden rake he was washing it with! Looks beautiful now.
  3. Scott's Mobile Detailing
    awesome job...man i hate mustang paint...it is sooo flat...i can speak from my old gt....and many i have detailed....not fun paint
  4. Gemini13
    Gemini13 Obsessive Detailer
    Nice. Cobra + ProCharger = FTW!!!
  5. detaildoc
    detaildoc Guest
    Awesome transformation. That reflection is insane.
  6. mixxer
    Thanks all the owner was stuned when he saw it i dont think he thought it would come out that well. Yea its a beast with the procharger and built motor, it put down 570 on low boost on a mustang dyno so on a dyno jet would have been close to 600.
