Cleaning inner wheel barrels
Discussion in 'Car Detailing Product Discussion' started by TLMitchell, Apr 8, 2009.
  1. TLMitchell
    TLMitchell Birth of a Detailer
    Posted here, there & everywhere....
    What we have here are OEM coated, cast aluminum wheels from a 2004 GMC Sierra. They've seen 60k+ and 5 Ohio winters without ever getting a really thorough cleaning inside and out.
    The outer wheels are in pretty decent shape with just a few defects in the coating where wheel weights have been attached. They clean up well and take a shine, they're rarely left very cruddy for long periods. The inner barrels are a different story though.
    Believe me, the pics are AFTER cleaning attempts! They were pitch black before!
    My primary goal is to clean these up as well as possible and apply sealant and do 'em once a year every Spring. The visible portions through the holes in the front detract a bit from the overall appearance.
    In attempting to clean the inner barrel I first tried a generous dose of P21S Gel and let it dwell for an hour. I then scrubbed the surface crud with a wheel brush getting close to the results shown. Thinking I needed something considerably stouter I applied Purple Power APC full strength and let it dwell taking care that I didn't get any of this nasty stuff on the front of the wheels. Not much improvement.
    I then attempted a few other things in spots..... of everything I tried a Brillo pad produced the most favorable result with a TON of scrubbing. I also gave a PowerBall a whirl with Wenol red, Meg's Mag & Aluminum Polish and other lesser products with the best results appearing near the openings where exterior cleaning may have kept them from getting as bad as the rest of the barrel. At this rate using the products and methods I've attempted thus far I might get some decent results if I kept at it for a week or so........ per wheel, probably! There's gotta be a better way....
    I'd appreciate any thoughts, comments or suggestions that might lead to some improvement. I don't expect perfection after 5 years of neglect but I'd like to improve the appearance, at least what's visible from the outside of the wheel.
    Thanks in advance...... TL
  2. slanguage
    Try claying them. Afterswards, use some never-dull (with a little elbow grease) then seal them up with a dedicated wheel sealant like Rimwax.
  3. michakaveli
    Tardis maybe?
  4. slanguage
  5. TheJakeR
    TheJakeR Any Rag Vehicle Washer
    +2 on the tardis. Nica wrote a thread on it a bit ago and he was offering to ship some to members if i'm not mistaken.
  6. supercharged
  7. 911Fanatic
    I could be mistaken, but the inner barrels look like they are damaged, not dirty, To me they appear pitted. Are the barrels smooth or rough. The wheels come clearcoated from the factory so should be dead smooth inside as well. If they are rough, its from corrosion and they need to be refinished.
  8. Buddy
    I agree, The only product that has ever done anything to lighting up the pitting is ZEP-A-LUME which is an acid that can be diluted to your situation or not. Sorry to see that happened to you...:shrug:
  9. Nica
    Yes, I would have to agree with 911 on this one. Looks like the rims clear coat has taken a beating, not sure if you'll get them 100% clean but I'm curious to see how you make out.
    Keep us posted :waiting2:
