clay bars adams or swissvax
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by cleanfiend, Feb 21, 2010.
  1. cleanfiend
    cleanfiend Jedi Nuba
    Swissvax paint rubber (blue) and Adams grey clay bar
    which is the better between these two clays? are they both similar in terms of aggressiveness?
    thanks for your help guys
  2. agpatel
    agpatel OD On Detailing
    From what I have read yes they are similar. SV one is a med aggressiveness and not really worth the price as it is somewhat hard and not really worth it. The uber clay is a nice one as well if you are just looking at buying from DD.
  3. cleanfiend
    so is the adams clay bar medium aggressive as well?
  4. agpatel
    It is your middle of the road clay.
  5. Aesop
    Aesop Jedi Nuba
    Get the clay magic bars, or Sonus green.
  6. cleanfiend
    how would you say it compares to blue claymagic? thats what i have right now
    those are the two clays that i have right now lol.
  7. agpatel
    Pretty much the same as clay magic blue. Blue may have a itty bitty bit more bite, but if you are happy with blue just stick with that. It is a great clay and cheaper.
  8. pektel
    pektel DB Forum Supporter
    adam.s grey is more aggressive than clay magic blue. I would only use adam.s if you plan on polishing after.
  9. dankfanatic
    dankfanatic Guest
    bilt hamber soft clay!
  10. agpatel
    Blue and adams gray to me seem like the same level almost...and both have very light marring when I have used them.
  11. cleanfiend
    between adams grey clay and claymagic bkue, which would you say is the easiest to use (ie folding, not falling apart)
  12. DJ_JonnyV
    DJ_JonnyV DB Forum Supporter
    Amen to that. Definitely plan on a light polish following Adam's. Never used the Magic Blue, I think I have some laying around here somewhere. I would almost classify Adam's Grey as medium / high aggressive due to the fact of having to polish afterwards. I happened across some Canadian clay that I use the hell out of for just claying and then waxing. I've found a quick clay using this makes the wax job that much easier for on / off and better shine.
  13. pektel
    in my experience, it isn't so much the type of clay that makes it difficult to manipulate. I've found that once the clay gets cold enough it not only is more difficult to fold and re mold, but it's effectiveness is also greatly reduced the colder it gets. So as long as you are using it in above temps of, say, 60 deg. F any clay should work just fine as far as pliability is concerned.
  14. pektel
    i'll also add that short of bilt hamber, my favorite fine clay is sonus green. I.m strongly considering trying out di's clay too. But i have a bunch to burn through first.
  15. Aesop
    Aesop Jedi Nuba
    If I am at my shop I soak it in water from my tea maker, If I am mobile I stop at a Dunkin Donuts(small cup of hot water is free at most of them). Let it soak until its soft and easy to shape. Do not put into the water when its super hot though. I think the clay magic is great stuff, I have not used the Adams clay and will not comment. I can only say this I am not looking to switch clays.
    Now if you are looking to clay and not polish I think Sonus Green clay is your best choice. Or a decon wash setup.
