CG CW&G CG Barebones CG Citrus Wheel Cleaner 1z Anti-Insekt 1z Cockpit Stoner Invisible Glass P21S TCC Optimum No-Rinse Stoners Invisible Glass Amazing Roll-Off CD2 Leatherique 3M Adhesive Remover 3M Blue Tape 3m Black Finishing Pad 3m White Compounding Pad LLC White Polishing Pad Meguiars #84 Compound Meguiars #83 DACP Meguiars #80 Speed Glaze Prep Kleen Collonite 845 IW Rejex (wheels) Klay Magic Clay Griots Garage Speed Shine Plexus Sonus Motor Coat and Trim Schmitt Swissvax wheel brush Meg's Wheel Brush Grout Sponge This in one of the most neglected vehicles I’ve worked on. It’s hard to believe that its only 2 years old. I gently chastised client that he needs to take better care of his car. The Patient Brake dust baked onto wheels requiring acid cleaning and it still couldn’t remove all of it. Soaking in CWG and P21S TAW Zero Beading. Hasn’t seen a wax job since new. That’s actually concrete stuck on the paint. Dirtiest Clay I’ve ever seen. This is after doing 1 Door!!!! 50/50 after compounding No idea what this is. Door Scrape After hitting it with some wool Door dings marks After wool and polishing Cloth after cleaning inside rear window. Finished shots
The brake dust was baked on. I had to use acid and elbow grease to remove what I could. I probably could have gotten it all off but I only had 1 day to get this detail done.
