I just tried this stuff tonight for the first time tonight after thoroughly washing my Taurus since February, performing any detailing to it for that matter, and was blown away how easy this product comes off. Now keep in mind that my paint surface has some lightly visible water spots, and I did not clay it as I didn't have time, but wanted to bring sexy back and finally use some of the products I have accumulated. I applied the product using a red 5.5" CCS pad with my UDM @ speed 1-2. The product came off EFFORTLESSLY. I used the Uber No Name towels from Phil. I would glide the towel across the paint with no pressure and it was coming off. It definitely does not have any filling properties like M-Seal, but dang does it go off easy. Perfect if you're in the mood to wax your car, and have a few hours after a busy day at work. I even applied it to the glass surfaces and it came off as easy as the paint. What are others thoughts on this product?
I tried to apply thin coats and went over the area just as if I were buffing, so about 5-6 sweeps across the worked area. The initially applied areas I started to wipe off right after buffing (giving a very brief moment to haze), and towards finishing the car I was extending my haze duration. I ended up applying it to the fender and both doors, and the product came off just as easily as if I had just applied it and . The surface after application was not that smooth, there will still some light drag on the paint when gliding your fingers. This morning after it had cured the paint was very smooth. This experience was impressive, considering it was fairly hot yesterday, probably in the 80's and at least 50% humidity when I was applying the product. But no direct sunlight.
Here are some quick photos I took during lunch. It was very difficult to capture in the photos, but the first thing that caught my eye was how nicely the very fine metal flake particles are visible and stand out, not to mention the nice reflection. You can easily notice them a few feet from the car :thumb: See for yourself, this product is really outperforming any expectations that I had as far as looks. I think it does a better job than M-Seal as far as bring out the minute metallic flakes.
I never cared for it all that much. We saved it for "wash and waxes" I had a 16 oz bottle that I had as a sample. I found it to deliver some quick results but lacked in dependability and took too much product.
