CG Sticky Gel Dilution Ratios?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Emile, Aug 17, 2009.
  1. Emile
    Emile Welcome to Detailing
    Hi,
    What dilution ratios are people using for Chemical Guys Sticky Gel? I have two 32oz bottles at full strength and two 32oz bottles at 2:1. Never tried it full strength, but how far are you guys diluting it for regular cleanings? And how powerful is this stuff at full strength? It's pretty impressive at 2:1 but I don't know if I want to dilute it much further because then it seems like I would lose all the benefit of the clingy gel.
    Thanks,
    Emile
  2. agpatel
    agpatel OD On Detailing
    4:1 if your wheels are not that dirty, and 2:1 if they are pretty dirty, that is what i dilute mine to. Add a little citrus wash and clear to make it more of a gel and give it some clinging ability, I would guess you can use some other soaps but have not tired. Foaming spray head will also help alot, I love my foaming spray heads for my bottles of APC, wheel cleaner, and leather cleaner.
  3. memnuts
    memnuts Any Rag Vehicle Washer
    Wow I think that is the suggestion I was looking for. I have the CG wheel gel and am not at all impressed with the stuff. I am going to try that as soon as I get home.
  4. Dsoto87
    Dsoto87 Jedi Nuba
    So at full concentration is this stuff a real gel? Can anyone compare it to p21s?
  5. Emile
    I have them both. Sticky Gel is more watery (in original form) than P21S Gel, but I'm not saying it's bad. I have tried a few gel wheel cleaners and the P21S Gel is the most "gel-like", with Sticky Gel probably being second.
    agpatel, how much Citrus Wash & Clear in a 32oz bottle? And where did you come up with this solution? It says nothing like this on the container.
  6. supercharged
    I use mine 1:1. It never failed on me. On someone else's car though, I usually go straight to Megs WB, since inner wheels seems to be very dirty.
  7. agpatel
    Citrus wash is $18 for a gallon and $8 for 16 oz, CG does not have 32oz bottle. The adding of citrus wash I did not come up with but read it on here. I have not tried to add anything else, but I am willing to bet if you add some sort of regular soap, like 1/2-1 oz in a 32 oz bottle then you will get the cling you want. Only thing the soap is doing is sudding up so that the wheel cleaner can stay on it. Use a foaming spray trigger and it will help better.
    Like the below:
    Tolco Foaming Sprayer
  8. Emile
    Thanks agpatel, I have Citrus Wash & Clear and I have those Tolco Foaming Sprayers. I will have to give your method a try.
  9. Hum-Benz
    Hum-Benz Wax on..Wax off
    I was the one that actually came up with it. I tried several methods for it to "cling" then I decided to add some CW&C to it. With a 32oz bottle I add 1oz of CWC and then the typical ratio 2:1 for heavy and 4:1 for lightly soiled.
  10. Buddy
    Hey Dan, Good idea...I always think that there might be a chemical reaction when mixing products like this. Does this ever cross your mind? or is it nothing to worry about...Thanks...:thumb:
