CG Grime Reaper buoyancy?
Discussion in 'Car Detailing Product Discussion' started by 02blackout, May 20, 2010.
  1. 02blackout
    02blackout DB Forum Supporter
    What the heck, does anybody else have this problem? This is 5:1 and I havent read anywhere about somebody having this problem. If I vigorously shake it it only stays mixed up for a few seconds. Help??
    Look, its to the right of Sticky Gel:
  2. anbuzero
    anbuzero DB Pro Supporter
    never had a problem with it. i would say contact CG, you might have gotten a bad batch
  3. ndrom
    ndrom Two Bucket System Washer
    My Grime Reaper isn't that colour--it is more blue.
  4. nyrep1
    nyrep1 Obsessive Detailer
    yes a blue/ purple
  5. Emile
    Emile Welcome to Detailing
    That doesn't look like Grime Reaper. How about your original bottle? Is it blue/purple or is it that red color? Did you buy it from CG or another vendor?
  6. 02blackout
    I bought the gallon sized jug. It's a dark purple. I bought it straight from CG, too. I dont want it to be a bad jug, I have a BMW Alpina B7 detail coming up :(
  7. christian900se
    You know what product looks similar and would explain your buoyancy, CG Barebones is oily and is purple in color. I bet you that would explain the separation when combined with water, maybe they had an issue with labeling?
  8. ndrom
    Give me a sec, I'll take a picture of one for you.
  9. 02blackout
    I have Bare Bones and it mixed just fine. But Grime Reaper----- AHHH!HH!!
  10. ndrom
    Bare Bones shouldnt mix.
  11. ndrom
    I was thinking the same thing.
    Here is a picture of both next to each other:
  12. dankfanatic
    dankfanatic Guest
    LOL, my barebones is blue, and my grime reaper is dark purple. Paul assured me it was the right product tho.
  13. Mindflux
    Mindflux Welcome to Detailing
    I wonder if the labels are mixed up? Then again why is there a strike though on the apc UPC?
  14. ndrom
    There is a strike through the Grime Reaper bar code because CG does not use standard 12-digit UPC's. Their bar codes are for their internal system. If you scan all of the CG bar codes, many other them use the same first 12-digits, so they ring up the same.
    I can assure you, these bottles are correct. We have gone through a couple cases of Grime Reaper and Bare Bones (16oz and 128oz), and they are all the same, and all good.
    If your Grime Reaper doesn't mix with water, it isn't correct. Barebones is oil based, and will not mix with water.
  15. lifemal
    lifemal Wax on..Wax off
    My barebones was that rich blue, and grime reaper is normally a purple-ish color.
    But I've seen grime reaper in a few different colors now. So I have no idea.
  16. pektel
    pektel DB Forum Supporter
    My grime reaper mixes just fine. You do not have grime reaper. What are you trying to mix it with? Doesn't look like clear water.
  17. JonM
    JonM Guest
    I think it is water. The bubbles in it shows he may have just shaken it, hence the cloudy color. I could be wrong though.
  18. vtec92civic
    vtec92civic Nuba Guru
    wow. never used either product but either way that product in the bottle is red. It's isn't blue nor purple. I would contact CG. The sooner you contact them the sooner it can be figured out so maybe you will have some when your detail comes up and some of the correct stuff that is.
  19. vtec92civic
    Do you have a store or something. The background of the image looks like heaven LoL.
  20. christian900se
    Hmmm, my barebones is purple just like the picture of Barebones posted above. I will bet right now that the labels are mixed and you have been trying to mix Barebones with water and the stuff you think is barebones is mixing because it is probably Grime Reaper.
    Why don't you find a place to test each product on plastic to settle this once and for all.
