Has anybody tried this, it is supposed to be an upgraded version of the ONE waterless wash. I believe it is a little different than ONR, because you spray it on then you wipe away. I have not used ONR but I believe you wash your car like you regularly would them wipe it away could anyone chime in how it compare to ONR?
It's totally different. ONR you wash like normal, then dry the panel and that's that. With the CG stuff you spray it on, let it dwell to emulsify the dirt, then wipe. That removes the dirt, but leaves behind nuba which has to haze, then you buff off. It's a great idea but the actual usage of it is quite laborious IMO. It's quicker for me to ONR, then hit it with a spray wax.
So long as the car isn't absolutely filthy, you'll be fine. Especially with ONR, I think you would be quite surprised by it, I know I was.
