CG Diablo spray head
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by cleanfiend, Feb 28, 2010.
  1. cleanfiend
    cleanfiend Jedi Nuba
    does the standard spray head that chemical guys sends out with all of their products work fine for Diablo wheel gel?
    or would i be better off using the type of spray head from a poorboy's product?
    thanks for your help guys...im trying this product out for the first time tomorrow morning
  2. Emile
    Emile Welcome to Detailing
    The standard CG square-shaped sprayers are actually pretty decent, but I would opt for using one of the gray Poorboy's sprayers. Take the strainer off and untwist the sprayer tip quite a bit...if you don't mind spraying in a stream, that would be the best way to go because even at 3:1, Diablo Gel is extremely thick and spraying in a stream would ensure the smoothest flow of the gel/water mixture.
    But play around a bit and see what works best for you.
  3. agpatel
    agpatel OD On Detailing
    I use the p21s spray head that you get for 5l jugs as it is meant for gels. It will spray a nice fan pattern if wanted.
  4. edwinbong
    edwinbong DB Forum Supporter
    will be experimenting with diablo once the weather clears up around here
