CG 50/50 Help?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by slanguage, Aug 24, 2009.
  1. slanguage
    So, I just got some Chemical Guys 50/50 wax last week. Now I have never used any of their waxes before, so I need advice.
    I know to obviously put it on thin, but how long do I wait before removal?
    Also, how long do I wait in between coats if I decide to do multiple coats?
    How long is durability? 3-4 weeks? or longer?
    Thanks for any tips/advice about this product.
    -Roger.
  2. supercharged
    I use WOWO method with pretty much all my paste waxes, except RBOE. It is the easiest method. As far as layering, I put another coat of wax 12 hours later. As far as durability, it depends on wheather the vehicle is a daily driver, garaged, etc...Anyway you should get 2+ months from a single coat.
  3. bryansbestwax
    WOWO , new formula will give ou 6 to 8 weeks. old formula is about 4 weeks.
  4. SpecC
    SpecC Wax on..Wax off
    from my experience on a couple of daily drivers, it was about 8 weeks in san francisco
  5. Dsoto87
    Dsoto87 Jedi Nuba
    Specc are you in SF right now?
    Sorry to get off track
  6. dan avoN7
    dan avoN7 Virgin Detailer
    Do you guys wax on one panel and immediately buff it off within a minute? Or is it fine to do the entire car (should only take ~10-15 minutes) and then remove it? I wasn't sure if it's bad to let it sit while applying a coat to other panels. The detail will be performed in a garage, so cool weather and no direct sun light.
  7. supercharged
    It works either way, application method is pretty much your personal preference. I personally do majority of paste waxes wipe on wipe off application, I don't let it dry, otherwise it might become a pain to remove...you can let it haze if you wanted to, it might become harder to remove and might require a spray of QD to remove any hazing, although that shouldn't happen with 5050, it might happen with other hard paste waxes like Megs #16.
  8. MKV
    MKV Virgin Detailer
    I just waxed my car this morning with 50/50 and I let it sit for 5 min then remove it. I did 2 coats on the roof and hood 30 min appart. The car is in the sun right now and it's not sweatin at all. What a shine !
    Sry maybe off topic but anyone use a PC with blue pad after wax? Does it takes too much wax away? :shead:
