Ceramic clear coat
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by M_1313, Aug 5, 2008.
  1. M_1313
    M_1313 Any Rag Vehicle Washer
    Hi,
    I was wondering, when does mercedes started to use ceramic clear coat.
    I might have to polish a 2000 SLK soon.
    Thanks
  2. detaildoc
    detaildoc Guest
    Not sure of the exact year, but I believe it was recent like in the last couple of years, so the 2000 won't have it.
  3. richy
    i believe it was in 2004.
  4. 911Fanatic
    I think richy is right. It was 2004 or 2005.
  5. Nica
    That's about right 2004/2005 but I have seen older Merc. have a hard clear coat as well :confused: not sure why but they felt just as hard as the new ceramic clear coat.
  6. GBS
    GBS Wax on..Wax off
    I not sure about the year but my wife's 05 E500 has it.
  7. M_1313
    Thanks guys
  8. Calgarydetail
    I belive they no longer use ceramiclear, my dads 08s550 dosent have it, they have a new paint that they are using, supposted to be even better
  9. Reflect
    What's the main difference between the two?
  10. M_1313
    How can you know if the car has it?
  11. P1et
    There should be a paint code on the vehicle, you can refer to it that way.
  12. David Fermani
    I was told differently. How sure about this are you? 1 way you can tell is that there will be a "C" in the paint code indicating it's Ceramic.
  13. Nica
    I thought it was Infinity that upgraded to the new clear coat, I didn't know that Merc. did as well :shead:
    hmmm...interesting :thinking:
  14. Calgarydetail
    I will go check the paint code tom (assuming he takes the jag) but i remeber when we bough the s550 I was told that we had to request the cerami clear, they had some new paint technolgy that was better....but ill double check as soon as i can get my hands on the benz
  15. sneek
    sneek Nuba Guru
    I am pretty sure the scratch resistant clears started in 2002 but only on the CL's. Then on July 14, 2003, the W170's (SLK) and the R230's (SL) got the C in the paint code. Sept 1, 2003 marked when every vehicle made in Sindelfingen got the ceramiclear. I think that all of the Bremen got ceramiclear Dec 15, 2003.
    haha what can I say...I used to/ still detail a lot of Mercs.
  16. M_1313
    thanks for the help guys
