CarPro IronX Soap Gel – a new product from C.Quartz, clean your car and remove brake dust iron contaminants at same time, it leaves a very smooth and slippery surface and requires a very little to clean dirt and salt very efficiently, round 20ml. More like gel shampoo you rub on the surface with a damp sponge or waffle weave micro fibre towel and rinse it off, pH neutral, you can use it on any surface. Rinse surfaces thoroughly after use Just got an unused (as yet) sample, stay tuned
check out the uk forum, you can see there small review. not much money , and not much quantity per car wash comparing to its results.
I just got my order for the new version of ReLoad, IronX 50mL and IronX 50mL Soap Gel. I am going to have to try out the Soap Gel...perhaps on the Honda !!
