Carnauba Hazing after sitting in the hot sun?
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by ampbmw, Apr 17, 2012.
  1. ampbmw
    ampbmw DB Forum Supporter
    For those in warmer climates like Ca, SC, FL, GA, etc...
    After applying carnaubas, even when I apply thinly and let cure for long hours, if I let the car sit in the sun the following day I will get hazing in the hood. Maybe it's due to engine heat too.
    For this reason I really use more polymer sealants these days like Zaino, but I really miss the deeper wetter look of my swissvax that's been on the shelf sadly.
    Is there any tips you pros can give me on how to avoid this? Or is it just inevitable in warmer sun beaten climates?
  2. 01GreyStangGT
    01GreyStangGT Any Rag Vehicle Washer
    You might try a sun friendly carnauba like Poorboys Natttys waxes and see if you still get that.
  3. EbbeJ
    EbbeJ Jedi Nuba
    A wash will most likely remove this, has happened to a few cars I've worked on if it was in the middle of the summer, but after the first wash it's gone and doesn't come back.
    Kind regards,
    Ebbe
  4. JSF721
    JSF721 Jedi Nuba
    I find it happens if the car is hot when you apply the wax or if you dont get it all off during the buffing stage.
  5. Dr Oldz
    Dr Oldz Birth of a Detailer
    That usually occurs with higher nuba content waxes. I find a slow final wipedown helps reduce this but some waxes it is just about unavoidable. You can let the vehicle sit in the sun for a few hours and then do another wipedown and this will make sure that it doesn't rehaze. I believe that if you even read ur SV jar, that they suggest letting sit in the sun and then doing another wipedown. Other waxes usually do not have the happen unless they have a high nuba content.
  6. umi000
    umi000 Any Rag Vehicle Washer
    What I do is, after the initial buff off, is I wait an hour, then do a second, final buff, using chilled water or QD - read this recommendation from Dom of Dodo Juice to help with Supernatural sweating.
  7. Danny
    Danny Nuba Guru
    Do a chilled distilled water wipe down and you should be good to go:thumb:
  8. mrd0t
    mrd0t Obsessive Detailer
    Any pictures of what this might look like? Great info as always!
  9. bryansbestwax
    QD or distilled water. Some of the wax guys call it sweating, it the oils in the wax coming to the top.
  10. EbbeJ
    EbbeJ Jedi Nuba
    Looks a bit like micro hologramming
  11. supercharged
    I agree.
  12. armenakadino
    armenakadino Birth of a Detailer
    can someone explain the chilled water wipe down in better detail
  13. DJBAILEY
    DJBAILEY Birth of a Detailer
    It is same as spritzing the car down with a QD and wiping except you are using a spray bottle with very cold water.
  14. Raven
    Raven Any Rag Vehicle Washer
    I use the chilled water method when I want to lay down 2-3 layers of wax fairly quickly. Works a treat!
  15. Smyly
    Smyly Virgin Detailer
    spray bottle with some cold water and a gentle wipe down..:) living in Alabama I deal with this all the time. Not only is it hot here but very humid as well :(
