I read a thread on here by the same title and it got me inspired, I wanted to pickup some new CG stuff so I figured Id show you guys, I also had the monster towels in my cart but removed them. Anyways this is what it looks like. Tell me what you think? Also, someone mentioned free samples. How do I ask for them and what should I ask for? Thanks, Vik Incase the pic is too small, Its: 1 Gallon of Diablo Wheel Gel 2 Gallons of P40 Detailer Disregard Microfibers (I just removed them) 1 Grit guard 1 Gallon of Sofast Odor Eater 4 Heavy Duty Sprayers (For my degreasers and wheel brightener) 1 Gallon of Extreme Slick Detailer 16 Oz Combo Leather Cleaner + Conditioner 1 Gallon Hand pump Yellow Microfibers (Which I might keep) Keep in mind this is all mostly for my own cars, and maybe some friends cars.
I would add (if you don't have applicable product already): Fluffer towels for removing product are great to have - hard to beat the pricing too. Maxi-Suds II has great foaming action for use in foam cannon/gun and a gallon will go a LONG time.
I have both synthetic and pro detailer......... save some money and just get the Pro detailer, you will use it more then the other. Trust me LOL
I was planning to use the synthetic as a clay lube and p40 for final wipedowns. Do you think p40 will do well as a clay lube, since it has the caranuba in it?
^^^ good point, ONR is not as slick as say luber, but if you add a little car shampoo to the mix it becomes very slick. No, the pro detailer will not work as a good clay lube. Id say get a gallon of luber, it is a great product, but it goes quick. If its for personal use then its great.
Good choice on the mf towels, the bulk 12 pack is at $23 right now. I've seen it go down to $18. I think the 16x24 sized towels are $13 atm, so if you like that size you might want to consider that for better deal. Any reason why? I was planning on getting synthetic. Was cautious on pro detailer since it contains carnauba and it may affect sealant bonding. Then again, maybe I should just stick to v7?
wanted to try them both and ended up really liking the pro more. I was initially impressed with V7, but i live in a hot dusty area and it lasted maybe two weeks at best. So I no longer use V7, as a detailer or sealant. I do occasionally use the Syn detailer....
In the comment box, ask for a sample. You might want to give EZ Creme Glaze a try? I like the VRP and the G6 trim gel too.
I still like these towels a lot POLISHING TOWEL - Edgeless NO-BUNCH MICROFIBER TOWELS 16 x16 (3 Pack) they are great to remove polish and waxes I need to order more for sure
