Buying a Flex...
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by sal329, Jan 26, 2009.
  1. sal329
    sal329 Nuba Guru
    Any advice on what pads to get? I have 4" pads only and I know they will not work with a Flex so I need a new assortment of pads. Any other good tips, words of advice or caution with the flex?
  2. Brian N
    Brian N Jedi Nuba
    Which flex are you buying the orbital or the rotary?
  3. matrix_808
    matrix_808 DB Supporter
    Get ear plugs cause that thing makes a very high pitch sound.
  4. Buddy
    Really, I've never heard about that before...:shrug:
  5. RussECU
    RussECU DB Forum Supporter
    6" pads work nice
  6. Bunky
    Bunky Guest
    i Have heard some who have made custom backing plates to accomodate 5-in pads.
  7. sal329
    sal329 Nuba Guru
    Sorry I am getting the DA version 3401
  8. Darkstar752
    Darkstar752 Horizon Detailing
    There's a problem with the felt ring needing to be lubed and and glued down or something, check the Flex section of this forum.
  9. SSTG
    SSTG DB Forum Supporter
    That's the old style.And was attributed to excessive user (operator) pressure. I've never had a problem with either of my flex's. Quality machine.:thumb:
  10. DJ_JonnyV
    DJ_JonnyV DB Forum Supporter
    I use everything from 5" to 5.5" to 6.5" with my 3401. I was lucky enough to get one of the very few 5" BPs from Powerhouse Distributing a while ago, and while it really doesn't leave you any overhange with the pad, it does allow using 5" pads in certain circumstances. For a little extra bite, I'll go with the 5.5" pads. If the car just needs a light cleanup with some minor swirls, then I'll use 6.5" with the standard BP or the 5" BP. I'm usually too lazy to change it and mainly leave the 5" one on. When applying sealants, I always use a LC red 6.5" pad which has always worked well for me on the 3401.
