bryansbestwax vs Lexus ES300(Incedibad B/S repair)
Discussion in 'Show and Shine' started by bryansbestwax, Mar 28, 2011.
  1. bryansbestwax
    I was contacted by the owner of this Lexus ES 300, to fix up the body shop debacle of a repair they did to his hood and fenders, as well as polish up the rest of the car to make it look better. The pictures you will see at the start will shock you, those are “finished repairs”.
    I started with an ONR wash on the outside. I then clayed the car with Werkstat Blue clay, which came out pretty clean as the owner clayed it late last year. I started by tackling the hood with Optimum Hyper Compound and a foam compounding pad. The hood took 3 passes to rid the hood of all the sanding marks, leaving only the DA sanding curlies that were very deep. The hood was then followed up with Optimum Hyper Polish and then Super Finish to get rid of the micro marring that was left after polishing. The rest of the car was finished with Optimum Hyper Polish and a few other polishes. The LSP was a prototype wax and precleaner from Eshine.
    The start
    Fenders were is rough shape as well.
    I start by spraying the compound on the hood
    But then figured out it was better to spray on the pad itself
    The compound spits a bit, but does not dust at all.
    After a few passes of Optimum Hyper compound
    I had a hard time focusing on the 50/50 on the trunk, but the right side is polished.
    Used these for LSP process
    And the finished pics
    All work was done outside in -2 degree weather.
  2. BoostedMk6
    BoostedMk6 Jedi Nuba
    Nice job.
    What machine did you use?
  3. bryansbestwax
    three machines, mostly the small and large flex rotaries and I played with the PC a bit, but found the polish works much better on a rotary
  4. billyblooshoes
    nice job bryan! was that the prototype wax in that box you have picture?
  5. bryansbestwax
    yes it was
  6. Kaban
    Kaban Welcome to Detailing
    Nice job. That's an IS300 btw.
  7. bryansbestwax
    yes it is, I type to fast sometimes, your BP will be going out today
  8. kyoshiro
    kyoshiro DB Forum Supporter
    ^^ was just about to tell you too bryan LOL
    nice job nonetheless, i see you be soldiering on in -2c :D
    did you LSP up his steelies and dress his winters? =p
  9. cptzippy
    cptzippy Jedi Nuba
    Nice job. Noticed you said it was all done outside in -2 degree weather. Doesn't that effect the products you use?
  10. bryansbestwax
    yes, you have to work with the sun. It's make a hard job even harder. Patience and experience.
  11. bryansbestwax
    no but I did clean his regular wheels that were off the car
  12. belcadimer
    belcadimer Virgin Detailer
    great job! Gotta love body shops, when I did this full time, body shops were my main clients, they didn't want to finish the job or didn't have time to clean up their own mess that they did to the vehicles.
  13. bryansbestwax
    ya, I couldn't believe this one though.
