bryansbestwax vs Black Acura NSX with Opticoating
Discussion in 'Show and Shine' started by bryansbestwax, Jul 22, 2011.
  1. bryansbestwax
    This was a new customer to me. He had done some research, and decided I might be the guy to help out his NSX look better. The car was in fairly bad shape, lots of swirls and scratches. We had talked on the phone and decided with a single step polish this time. After looking at the damage, I changed it up a bit and chose a bit stronger approach, that required 2 steps. He also wanted a coating done to the car and so I applied Opti coating.
    This detail was also done on the hottest day of the year, 130+ degrees outside with the humidity.
    The Process
    Wheels cleaned with AM Magnificent
    Tires cleaned with AG CWC
    Presoaked with APC
    Washed with Werkstat Auto Body Wash
    Polished with SIP then Super finish via a DA
    Washed again with Werkstat mixed with APC
    Wiped down with Pre Paint Cleaner
    Applied Opticoating
    The before
    Inside After the wash and Stripping of wax
    After polishing
    Outside shots
    Thanks for looking
  2. Max405
    Max405 DB Forum Supporter
    NIce! Great job.
    Love those NSX's with Acura logos on the nose.
    Thanks, Joe D.
  3. hamza7
    hamza7 Welcome to Detailing
    Great job Bryan, now when you say Pre Paint Cleaner, does that mean something like a IPA mix or a sealant
  4. bryansbestwax
    its a body shop water based solvent cleaner
  5. mrgolfrider
    Brought it back to life Bryan! Good job man!
    Did your products for polishing act weird in such warm weather?
  6. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    Great correction! Car looks amazing.
  7. Socal Brian
    The NSX looks great now!
  8. bryansbestwax
    I stuck to the DA to avoid heat issues. I lost about 5 lbs doing the detail.
