BMW E39 M5 Correction
Discussion in 'Show and Shine' started by Mpower4life, Nov 17, 2012.
  1. Mpower4life
    Mpower4life DB Pro Supporter
    In for full correction, 2002 BMW M5, Titanium Silver. A very forgiving color as you probably know with it's metallic flake and light silver, the process begins under proper lighting conditions to highlight defects. Also noted, this was my first full correction using the new Rupes 21 (thanks again Kevin). Also wanted to make a statement about how well this can finish down and cover a lot of area quickly as it cuts through defects like no other. 3 inch Rupes was used for the smaller tighter areas as the 21 has well, a 21mm stroke. A seriously deadly combo I must say.
    Vehicle was washed with foam gun/ wheels cleaned with Sonax FE/ contaminants reduced using an iron filing removal product/ /blown dry with Master Blaster( awesome tool by the way) speed prep towel to remove remaining contaminants
    Polishers:
    Rupes 21
    Rupes 75
    Compound:
    D300
    M101
    (in light of a "test" I wanted to show how on some colors you can definitely get away with this combination and get a great finished result)
    LSP:
    Blackfire
    Maxi Suds II and Citrus Foamed on using Deionized water
    Washed again to remove any deeper remaining grime with Schmitt Wash Mitt
    Sonax being washed away along with... well, dirt
    For the M enthusiast like myself....
    Engine compartment as well as other areas steam cleaned with the Dupray
    Hood with some defects present
    50/50 of hood (again, hard to pick up defects with camera so I apologize)
    some more hood defects
    defects removed
    Some deep scratches in random places needed some wet sanding to be removed
    Roof needed some love
    removed
    Trunk lid defects
    Rupes going to work
    50/50 (hard to see)
    Roof again
    Removed
    pillars before
    after
    a few random afters
    deep scratch that ran a lengthy part of the door
    remaining deep scratch that was wet sanded away
    gone
    was able to get a few sun shots while the weather lightened up momentarily after compounding
    exhaust tips needed some attention.... 2 my detail.
    someone took something far too aggressive to the tips at one point.... ouch
    if you notice a faint scratch through the middle.... wet sanded away
    much better
    defects on door
    removed
    more scratches
    removed
    rear section
    removed (license plate area not corrected yet)
    license plate
    after random
    few sun shots 2 days after job ( paint is not the best to show results on )
    not sure why there was a spot on the camera lense here
    line in hood is clear bra
  2. 604_Snooze
    604_Snooze Obsessive Detailer
    Hello, did the rupes 21 vibrate like the PC or GG6?
    How much did you spend on the 21 and 75?
  3. boredstudent3
    boredstudent3 Wax on..Wax off
    nice work Paul.
    putting the rupes family to work...lol
  4. Mpower4life
    no the rupes does not vibrate like the others. very smooth. ill just say the 21 was under $400 and the 75 was under $300. contact Kevin Brown for more information.
  5. Mpower4life
    yes, the rupes family is getting along great as a team. lol
  6. Auto Concierge
    Brings a tear to my eye......................almost "Mark/Paul", doing great young(HUGE) grasshopper........................ see you in a few weeks.
  7. stingray23
    stingray23 Jedi Nuba
    great job. still my favorite M5.
  8. Mpower4life
    motivation to keep on keeping on.... thanks Bob.
  9. Mpower4life
    Can't argue it's all around abilities and styling.
  10. rjd598
    rjd598 Any Rag Vehicle Washer
    I agree with that one
