Blaster Dog & Cycle Dryer I am thinking of getting one of these, anyone have any experience with it or recommend a different one? Thanks a lot!!
You could get a shopvac, majority of them have the blower feature too. Get two things for price of one. Just my two cents
Not a bad idea, but I already have a vacuum that works great. So the question is will the shop vac be as good or better than that dryer, because I will be spending about the same.
This is the unit I use- Drying Unit - The AirForce Master Blaster Dryer Dryer features a total of 8 peak horsepower, twin fan, 4.0 HP motors that deliver up to 58,500 feet per minute of clean, filtered, warm airflow. Two switches allow users to set the airflow and temperature at 3 different levels. Use either motor (front or rear) independently or both simultaneously for maximum power. Five different nozzles enable users to position airflow where desired and eliminate water spots, 78 dB noise level, 100 –inch water gauge (water lift sealed suction measurement). •8 Peak Horsepower Dryer on wheels •12 foot cord •10-Foot Heavy Duty Hose •Heavy Duty Neoprene Blower •NozzleAir concentrator •Air streamer tool •Micro adaptor •Male/male adaptor •5 Piece Attachment Kit •1 Year warranty •Construction: Sturdy All Steel •Motor: 8.0 Peak HP / Two Motors •Air Flow: 58,500 FPM •Fan: 2 Motors / 2 Stage Dual Fan •2 Speeds / 2 Temperatures •Amps: 18 Amps •Hose: 10ft. x 1.5 inch Commercial Strength Flexible Hose •Nozzle: Heavy Duty Neoprene Blower Nozzle •Cord: 12 ft. Heavy Duty 3 Conductor •Weight: 16 lbs. •Filter: E/Z Change Foam Filter Vehicle Drying The Air Wand is a high-velocity air nozzle that blows air up to 200 M.P.H. to remove water, from surfaces and hard-to-reach areas. The Air Wand greatly accelerates nature's drying action with no adverse effects to existing fragile finishes and delicate surfaces. The new, revolutionary Air Wand saves work, time, and money! Never again use old, scratchy towels and elbow grease to care for your prized possessions. Simply attach the new Air Wand to the blower and get all your week-end jobs done in a fraction of the time, with a fraction of the effort -Air Wand - Description
Most good shop vacs have a blower function as well. If you are going to use it specifically for drying, maybe a smaller air compressor would be better?
Thanks for the info. If I am going to invest that much ($450) in one of these, has it totally replaced drying towels for you, even on vehicles with no wax (for the first one)? Thanks.
