Black Porsche Cayenne Turbo (+30 Pics)
Discussion in 'Show and Shine' started by autobahnshine, May 10, 2008.
  1. This detail was designed to be a Minor Correction detail, removing ~ 65% of the swirls.
    Wash Procedure:
    Z-7 Foam Wash, Two Buckets w/ Grit Guards
    Rinsed w/ Filtered Water
    Dried w/ Waffle Weave Towels
    Clay:
    Meg's Profesional Mild
    Meg's Last Touch
    Interior:
    Vacuumed
    Woolite (8:1)
    Z-10 on Leather
    1Z Cockpit on other surfaces
    Boars Hair brushes in Vents
    Other:
    303 On Tires
    303 In Wheel Wells
    Minor Correction:
    Menzerna 106FF/Menzerna 106FA
    (Although I love FA, the extra oils were more difficult to remove)
    CG White Pad (identical to old SONUS, and my favorite pads)
    3m backing plate
    Menzerna Wipe-Down
    Equipment:
    Defelsko Positest DFT Combo
    Brinkman
    EZ-Detail Brush
    Swissvax Wheel Brush
    Various Boars-Hair Brushes for vents, crevices etc
    Loads of MF towels
    Zymol Pre-Wax Applicators (used to apply J.S.)
    Sealant of Choice:
    CG Jetseal109
    LSP of Choice:
    Swissvax Concorso (applied w/ Zymol Wax Applicator... they're thicker than SV's)
    No Washing or Claying shots. I'll just skip over to the PTG readings! Everything OK!
    Now on to the swirls! 106FF/106FA worked great, but a few RIDS still remain...
    Before
    After
    Before
    After
    Before
    After
    More Polishing...
    Polishing the Clear Bra
    Rear Door Before
    Rear Door During
    Rear Door After
    Interior
    106FA was smearing... so out with a wipe-down to remove the oils!
    Re-Wash with Z7 in the Foam Gun
    JetSeal
    Choices, Choices... Lusso, Glasur, P21S 100%....
    Concorso it is!! :applause2:
    A good friend of mine removing the wax after 10 minutes
    And the afters....
    Swissvax Quick Finish
    Thanks for Looking !
  2. dsms
    dsms DB Forum Supporter
    Excellent work! JS topped w/ Concourso seemed to work really well.
  3. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    nice... good job...
  4. Usjdmtuner
    btw.. just curious on your before and after pics.. i still see some swirls left.. did you stop at that point?
  5. FMINUS
    FMINUS DB Pro Supporter
    Very nice detail!
  6. Nica
    Looking good, not a bad turn around, you can totally see the difference :thumb:
    Job well done thank you for sharing with us :applause:
  7. supercharged
    WOW! Looks amazing!
  8. Because this detail was a minor correction detail, only about 65% of the swirls are removed. Not every client wants to pay for full correction when chances are, it will see a tunnel wash in the near future :shrug:.
  9. Truls
    Truls Two Bucket System Washer
    Looking good....
    Gloss posh...
  10. Usjdmtuner
    gotcha...job well done.. lets hope the customer comes back to you..:mounty:
  11. Tonya
    Tonya Welcome to Detailing
    Very impressive!!! Thanks for sharing!
  12. detailersdomain
    great write up nice work!
