Black Camaro 1LE Corrected then Opti-Coated by Greg Gellas SignatureDetailing.com
Discussion in 'Professional Detailer's Studio' started by Greg Gellas, Jun 18, 2013.
  1. Greg Gellas
    Greg Gellas DB Pro Supporter
    While my first post in the Pro-Section, I have been doing this for a few years :) Decided to recently join DB! :)
    I was contacted for Opti-Coat on this new Camaro 1LE. We discussed the job and decided a 1 step polishing and Opti-Coat application would be perfect for the car, as it only had 700 miles.
    The 1LE is really a unique different car. A limited number of these cars will be produced.
    "From its red Brembo® front and rear brakes to its lightweight wheels and unique performance suspension, the 1LE PERFORMANCE PACKAGE is a tough-looking, aggresive entry in a steady lineage of TRACK-DOMINATING RACING MACHINES....RPO code 1LE was first triggered 25 years ago, and originally intended to enhance the performance of IROC-Z in SCCA Showroom Stock road racing events. It included 11.65-inch rotors with 2-piston aluminum calipers, an aluminum driveshaft, a special baffled fuel tank, specific shock absorbers, and stiffer suspension bushings. The 1LE was a well-kept secret and very few were built."
    To learn more about this Camaro 1LE just read the specs here.
    I began with the wheels, cleaning them with sonax full effect, a full wash, then claying the entire car, and then a wonderful dry using my CG blower.
    Some of the fenders had some rough scratches on the edges.
    The passenger side door had quite a bit of swirling throughout. It appeared to have been hit due to a very slight optical change in the panel.
    Some more damage on the trunk lid.
    What are those...!?!
    Although not confirmed, it would appear these areas were corrected by a PDR tech and either wet sanded or "buffed" out to level the area. After seeing this damage I decided to contact the owner, show him some pictures, and let him decide if he wanted it corrected or continue with a 1 step polishing. Without hesitation the the owner saw some pictures I forwarded and decided to go for full correction. This would add a bit of time to the job at hand, plus there was quite a bit of rain, so luckily he offered to pick up the car 1 day later. It was awesome that I had more time on the car, but I also had another car coming in. I knew I would be working late on this baby. The results were well worth it! Instead of dressing the tires, as it would rinse right off, I applied Opti-Glass to the windshield instead.
    Here is a 50/50 of the trunk area. I think the correction rate was pretty good for a 2 step correction.
    The 50/50 on the door was awesome and it corrected out really well.
    Here you can see the larger damage to the paint. This was probably from a rub on the door from another car. I heavily compounded this area and decided this wasn't worth chasing. I would rather err on the side of safe rather than break through the clear. I had taken a good amount of clear off already. While improved it was not totally removed.
    I corrected and then polished the entire car. I washed the entire car again with 50% dawn and 50% Citrus wash and clear to remove any dust and polishing oils leftover. I then followed up with an IPA wipe down to ensure I was down to bare paint to ensure Opti-Coat is properly applied. All of the trim, and paint was cover in Opti-Coat Pro.
    The after pictures show the results of quite a few hours of correction and polishing! :)
    As always, thanks for looking Greg Gellas! :)
  2. DAC17
    DAC17 Virgin Detailer
    What a sweet car. Made even better with some great detailing!
  3. supercharged
    Wow!!! Pretty freaking amazing!
  4. rwisejr
    rwisejr DB Forum Supporter
    Nice save. That looks amazing.
  5. 911Fanatic
    Looks awesome Greg!
  6. richy
    Greg, it look great and with OC, it will stay that way!
