Birds pooh + lady finger nail threat on Opti coat test unveil by KC
Discussion in 'Show and Shine' started by kc's, Sep 18, 2013.
  1. kc's
    kc's Any Rag Vehicle Washer
    Why Bird Poop Etched on our paint
    "Question: How long does it take for a bird dropping to etch paint?
    Answer: A few minutes." Mike Phillips
    "Remove Bird Dropping Etchings ASAP!
    It's important that you remove a bird dropping off your car's finish as fast as you can before it can cause any damage. Bird droppings contain Uric Acid and Uric Acid is corrosive enough to eat past a coating of wax or paint sealant and then begin to etch your car's paint." [urlhttp://www.asktheexterminator.com/birds/Bird_Droppings.shtml[/url]
    [​IMG] eg
    Many would have asked "I know it's probably futile as the bird poop etching has gone straight through the clearcoat but is there any possible way to reduce the sight of it"?
    so with this in mind his wife took out a tissue paper and begin scrubbing hard with her nail on a caked poo poo
    some would have reckon it should "not polish (by itself) as not able to remove the defect. It will require wet sanding...do not use bare fingers wet sanding automotive paint...period. You must control the sanding with a block and for this you want to use a precision spot "block" with 1500-1800 wet dry use lots of lube (detail spray or clay lube- preferably high quality clay lube)"
    ehhhhhhhh
    almost had an heart attack when at first I saw what the wife intervention
    this ride was corrected and Alien coated couples of months ago
    close up
    cordon off
    a good thing to test the Coating but not a good timing
    anxiously he and his wife stood by waiting ....like a first time parents
    before
    tada
    close up before
    tada
    Procedure:-
    Optimum Car Wash
    Clay with ONR as Lube
    Cutting pad With 101
    conclusion
    after 2-3 cutting passes - the ectch mark significantly decrease and finish with OPtimum black OHP & re opti coat
    once again Opti coat with stand the harsh treat of Enemy attack....and I almost had an heart attack when at first I saw what the wife intervention
    before
    tada
    tada
    remember before
    after 5 months of Alien coating
    kamunnickuob97 likes this.
