Anybody know the height of the CR system? (Need to make sure it will fit in the back of the HHR). Also, any experince with it would be great? Will it leak if I need to lay it on its side after use? Does it work? Where can I find the best price? Thanks! Todd
I know phil at Detailers DOmain sells them. His prices on everything are always fair and he ahs great customer service!!
I've been using my CR Spotless System since last summer and it works great, not worried about water spots is great. Oh and yes if you lay it on it's side after use it will leak water. The only draw back is that the resins aren't cheap and depending how bad your water is you may have to change them quite often. If you do decide to purhcase it I'd recomend you get the largest drum of resins, it's the most cost effective way to go. Well hope this helps :2cents:
Is this for someone that would only use it say once or twice every 3-4 months? Or is it geared towards everyday use?
Well to be honest during the summer I would use my CR every weekend, you can use it everyday if you want but it just means that you may have to change the resins a bit more frequently...during the summer I replaced the resins twice and so far through the winter I've had to replace the resins once. I have it at home, I need to replace the resins again. You can use it how ever you'd like and as often as you'd like..well that's just my opinion though.
