Best Bug Remover...
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Dust2Glory, Mar 15, 2008.
  1. Dust2Glory
    Dust2Glory Nuba Guru
    I currently use PB bug squash, but a little expensive for as much as i use it. Was wondering what you guys used?
    And is there anything CG carries? I've looked on the web-site, maybe I've missed it?!?!
  2. Dontsleeponit
    Dontsleeponit Jedi Nuba
    bugsquash works well for me even when I dilute it 1:1, have you tried that?
    CG body solvent? FMINUS seems to like that stuff
  3. eShine
    eShine Guest
    I find Bug Squash works better diluted 1:1.
  4. JLs Detailing
    I like Bug Squash at 1:1 too but for a cheaper alternative I use Majestic Solutions Bug Off diluted 1:1 and it works very well.
  5. mixxer
    mixxer Birth of a Detailer
    Pb Bs
  6. Black Diamond
    Black Diamond Jedi Nuba
    Megs APC+ works well also.
  7. Calogero
    Calogero Two Bucket System Washer
    Megs Bug and Tar Remover
    Bounty Dryer Sheets.
  8. Al-53
    Al-53 Welcome to Detailing
    The only bug remover I have used is the Duragloss one....and it works for me...not saying others are not better..but we do not have a real bad bug problem here..just mostly sceeters....
    Dissolves and removes bugs, oil and tar with ease. Works great on painted surfaces, fiberglass, chrome and glass. Will not harm clear coated paint or remove durable polishes.
    I just spray it on and the remains just dissolve and run with the product..17.95 a gallon..
    Al
  9. MWAUTOPRO
    MWAUTOPRO Jedi Nuba
    2 oz:5 gallons CWG and the Yellow Side of a Shmitt has never let me down on bugs. If there are a lot I soak a rag and drape them over the bugs to loosen them up.
  10. Tonya
    Tonya Welcome to Detailing
    Turtle Wax
    j/k
    PB is my favorite so far. Someone gave me Stoner Tarminator to try. I have not had a chance to use it yet :shrug: :rollinglaugh: it is to darn cold for bugs yet :rollinglaugh:
  11. Dust2Glory
    i normally use it i think 3:1... it's not that fact that it doesn't work, i'm looking for something more cost effective... I might have to check that stuff out. thnx
    I will look into the MS stuff
    Ok hold the phone... you use Bounty dryer sheets to remove bugs???:shrug:
    hhhmmm... will see if i cant get some at a local shop here
    sounds like too much work:afro:
    thanks tonya... maybe i'll just dilute NuFinish and see if that doesn't work!!!
  12. TexasTB
    TexasTB Obsessive Detailer
    Ditto on the bounty dryer sheets. Enlighten us please, because now I am very curious.....
  13. npb
    npb Virgin Detailer
    SC grime destroyer
  14. budman3
    budman3 Birth of a Detailer
    +1 for Bug Squash ... buy a 16 oz bottle today and you will get 32 oz through poorboysworld.com
  15. richy
    The Bounce sheet has me interested too. I use one under the seat to absorb odours..it works well.
  16. Utah12
    Utah12 Any Rag Vehicle Washer
    Hi:
    I'm new to the site with some questions. I looked for a link for the Bug Squash special mentioned here and could not find it. Could someone give me a link? I just purchased some 3M adhesive remover after being told it is a great tar remover. Bugs too? In any event I was a little concerned about using it on the finish of my sportscar. The bug squash may be the answer. Also has anyone used the hard sponge like pads used for bug removal?
    Utah12
  17. richy
    I've got a bug sponge (from AG) and the DG bug remover (can't remember the #). I only had a chance to use it on one car, as I got them late last year.
  18. Gemini13
    Gemini13 Obsessive Detailer
  19. Utah12
    Oh well, I'm not going to pay almost $20 to get 16 ounces of this stuff. I was looking at thier other stuff but I'm not educated enough to know what to get.
  20. Deep Gloss Auto Salon
    I have been using Surf City Grime Destroyer since last season and have been happy with it
    The original formula was very thick and hard to spray, the new formula is much thinner
