Backing plate stuck on Makita 9227
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by tors, Apr 23, 2010.
  1. tors
    tors Any Rag Vehicle Washer
    My 6" backing plate is stuck on my Makita 9227. I hit the 'lock' button on the rotary to unscrew the backing plate, and the plate won't budge. Any thoughts?
  2. bige441
    bige441 Any Rag Vehicle Washer
    man sorry to hear that but, in the words of Tim "The Tool Man" Taylor "more power". If you can't get it to budge you could try and cut it off some how with a razor knife of somthing similar.
  3. vtec92civic
    vtec92civic Nuba Guru
    i've had my backing get stuck on my makita 9227 before. It was like i could apply all my strength to it and it wouldn't budge but what i found to work was:
    while holding the lock button you need to give the backing a quick firm twist to break it free and from then it should start to unscrew. That's what worked for me and that should hopefully work for you.
  4. kc1337
    kc1337 Obsessive Detailer
    Some WD40?
  5. 911Fanatic
    +1. I've had mine get stuck before as well and I found that holding the lock in and giving the bp a sharp tug was enough to loosen it.
  6. vtec92civic
    funny thing is when tightening the backing plate it's not a screw or a bolt where you can continue to over tighten it and what not. It spins on and stops bam! Like a dead end street but i guess after a while of being used the heat has to do with maybe the threads in the backing plate expanding and contracting which are why it gets a little stuck on the machine.
  7. 911Fanatic
    My thoughts as well.
  8. agpatel
    agpatel OD On Detailing
    Once you get it off put a dab of anti-seize on the threads and you should not have the issue again as it will provide a bit of lubrication to remove the BP again the next time.
