used this for the first time the other night. nighthawk black pearl car polished with 85rd and ipa wipe down then cg wmf glaze. i let the hd sit for about 2 hours (was very humid but it always is here) and it never passed the swipe test. the person was coming to get the car so i had to remove it. and as i expected it was full of hazing. the car was heading to a car show in the morning so i got up and went to the persons house and wiped it down with the next morning and the hazing was removed. how long are you guys letting this stuff dry before removing. i searched and see people saying 30-45 mins ....has anyone had tpo leave it longer. or was this some odd interaction between wmf and hd
As John said, if its humid out forget about waxing, its just not worth the hassle. The AG Hi Def wax is like a sealant in that the drier it is, the easier it to remove. Trying to remove it earlier will be an exercise in futility as you discovered.
I'm having trouble working with this wax as well due to the humidity. It gives great looks and it's easy on easy off but it likes to sweat over and over in humid climates.
if is say 30 minutes, you should wait 30 minutes, and then remove...even though it's humid, you should at least do a swipe test after 30 minutes...
