Autoglym CWC question....
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by kakeuter, Feb 25, 2011.
  1. kakeuter
    kakeuter DB Forum Supporter
    I'm planning on getting a 5L container of CWC, my question: Do I need a special sprayer to have the cleaner foam up once it is sprayed?
    I've seen some videos on youtube of this product and when they are using the Autoglym sprayer it looks like it foams up a bit. Should I get the 5L and a 500mL to utilize the sprayer, or can I use a Kwazar?
    I guess the other obvious question: does this product need to be "foamy" when sprayed on to wheels?
    Thanks for the continued help everyone. Have a great weekend!
    -Kody-
  2. kyoshiro
    kyoshiro DB Forum Supporter
    im sure the kwazar will do just fine foaming it up, dont think it really has to foam up to do its job really lol. Just some gogo agitation should suffice.
  3. lasthope05
    lasthope05 Jedi Nuba
    AG CWC doesnt really need a foaming head to work but the foam does allow it to dwell longer. I personally didnt like it as the sprayer on the 500ml bottle sprays a concentrated stream of product and I wasted a lot of product just to cover the wheel. I just use a regular sprayer now. AG CWC is some good stuff. I've got 15L of it.
  4. Kilo6_one
    i have a foaming head and bottle from USplastics, it works great. Id love to try the Kwazar set up as well. But I like the abity of the foam to stick more then when I spray it with a standard spray head
  5. billyblooshoes
    i find that it works equally as well no matter how you spray it, bit like reflect said, foaming head allows it to dwell longer. i personally use a large foaming sprayer just because i like that it clings better. i am going to try it with a kwazar sprayer next time i wash my car though.
    oh and here's a little seret for you guys. throw an ounce or so of wash soap in with your CWC and gently mix it up. it thickens the wheel cleaner nicely and also helps it to cling.
  6. kakeuter
    Thank you all very much for the advice, I can't wait to get this stuff!
    -Kody-
  7. Frankastic
    I do this with Brown royal 3:1. I put 1 oz of car soap to help it cling better as Brown royal is a runny wheel cleaner.
  8. luke093
    luke093 Welcome to Detailing
    Woah! That sounds like an amazing idea. Currently I use it 2:1 with a foaming head as I end up using a lot less.
