Audi A5 S-line Auto Finessed
Discussion in 'Show and Shine' started by adz, May 7, 2013.
  1. adz
    adz Virgin Detailer
    I worked Tough Prep on a rotary with a yellow 3M pad only working it between 1000-1200 working panel by panel, I am really impressed with the results
    so some befores:
    The car was washed with AF Lather then detared and iron removed before claying
    car was dried then put inside for the Tough Prep, you can see some 50/50 shots
    Before:
    After:
    Also going over the lights it did sharpen them up
    Some Mercury
    now some afters, after TC has been applied
    Now for some outside
    Thanks for looking
  2. Alex1389
    Alex1389 Two Bucket System Washer
    How much tough prep was applied to the pad while buffing, asI to have tough prep and looking forward to using even more now :)
  3. P1et
    Impressive results indeed!
  4. Marc08EX
    Marc08EX Jedi Nuba
    Great job!!!
  5. adz
    adz Virgin Detailer
    Thanks Guys, Alex I primed the pad first with a cross for the very first set, then all is required for the next set and there after is two pea size blobs, after a couple of panels I was cleaning the pad to keep it in good condition.
  6. Holden
    Holden DB Forum Supporter
    Impressive results by tough prep! Do you know if powerlock would lay just fine over tough prep?
  7. Alex1389
    Awesome thanks:) thats helped me heaps, great job by the way !!!!
  8. Frankastic
    looks very good! I love tough prep + tough coat combo. stupid easy to use.
  9. adz
    adz Virgin Detailer
    Not something I have tried with tough prep, but as tough prep is designed for sealants and doesn't leave any fillers and glazing oils behind I think it would make a good base for most sealants.
  10. cnut
    cnut DB Forum Supporter
    Nice work!
  11. Kenny T
    Kenny T Any Rag Vehicle Washer
    Awesome! Results are superb. Great work!
