1. cu2mike
    cu2mike DB Forum Supporter
    To owners of this pressure washer, I have a few questions,
    how is the foam cannon that came with it?
    If it's not good, how did you connect a different foam cannon to the unit
    How long have you had it, any problems so far?
    Thanks everyone!
  2. 911Fanatic
    Hey Mike. I had a look at one the other day for someone. It looks like the hose actually threads into the wand. If so, my advice is to get a regular wand from a local supplier and put quick connects on it to switch between your regular tips and foam cannon.
  3. cu2mike
    Thanks Ken! Now I just need someone to chime in about the reliability...
  4. co78
    co78 DB Forum Supporter
    it's a detergent bottle not a foam cannon that comes with the unit, so don't expect much if any foam to come out. I've spent too much money on trying different adapters to attach to foam cannons to find none of them work. I would get a different unit honestly if you want to use a foam cannon.
    Other than that, the unit works great.
  5. cu2mike
    So...... the bottle in this picture,
    It's not a foam cannon? Damn it......
  6. co78
    Yeah it's not a foam cannon unfortunately. It has almost the same pressure as using a foam gun attached to a hose.
  7. cu2mike
    Gah, looks like Karcher 5.85M then, at 100 bucks more. Wonder if it's just as reliable?
