How would AQuartz work on headlights? I know that Opti-Coat can be used to re-coat headlights. I'm looking for something to be used on headlights. I asked in another thread if Body Wrap would work on headlights. If it does I will not need to buy and Opti-Coat. I would also like to unlock the full potential of these products. I'm sure that there is many more used out there than what they are being used for. Any input please.
I think there is only one way to find out - is to try it. I used Cquartz on headlights and it worked VERY WELL and durability is excellent unlike any other sealants I tried on headlights before...
I'll make sure to try it then. I was just making sure that the nano coatings would work. I know that OC is a resin coating.
If you are protecting corrected lights that compounded off the factory UV protectant I'm not sure it will work perfectly. However as a protectant for a light correction where the UV coating was not removed it should work as well as the body.
