Can you use a rotary with a black finishing pad and low speeds to apply sealants? Can you also use a rotary and a low cut pad to remove water sports on glass? any recommendations? I currently have a Flex 3403 VRG rotary and want to remove the water spots from the glass using a LC green pad and power finish. Would that work? And in order to save a bit of time and ensure an even coating goes on the car, I was wondering if using a rotary to apply a sealant like DG or jetseal is recommended? Thanks,
Use a chemical cleaner to remove water spots from glass. I just had excellent luck with Duragloss 501 on a white CCS pad with my PC, speed 5. Then reassess if that doesn't fix the problem. KAIO may be another option to try, if you have it in your arsenal.
sure. just don't go above 900 rpms. It won't do anything extra by using a high speed, since it is not an abrasive type polish, it is a chemical cleaner.
i use a rotary myself on glass with a orange pad just fine for water spots. reputable people have even used m105 but I'm to scarred to try that.
Yes, I always use the rotary on the LSP. Just keep it moving and put it on the lowest RPM, this is something that you can 100% do. It actually works alot better and faster than by hand. Rich
sure you can use rotary to apply LSP, place near us uses rotary and 10" pad to apply wax on porche and Ferrari, i cringe every time i drive by there, not sure how they still in business
