This is my first post in this forum!!! Hope you all like! I recently had the pleasure of detailing this 2006 Ferrari F430 about 3 weeks ago! It will be pretty quick as I didnt take to many pics... The detail was about 8-9 hours in total and was pleasure to do! It wasnt to bad off as you will see in the picks. Just some touching up and some much needed added protection. Got the car started off with a foam bath!!! Then on to the 2 bucket wash deal. Some before shots under the sun after the wash... After the wash we proceeded into the garage and out of the elements where I started in on the interior first. Before: After: some vacuum and dusting Gave the leather a mild cleaning and protected seats with Elephant Leather Preserver. I love that this car has a manual 6 speed.... Big Plus Tapped her up and corrected the paint using Megs DA Microfiber system with 3M extracut! After corrected I ran 2 passes with the rotary using 3M polishes.... I use 3M most of the time!!! Alcohol solution wipes in between each pass. Protected the wheels with Jetseal109 Button up the motor with 303 protectant and a bit of Swissvax Metal Polish And as said it was going to be quick... sucks I didnt get to many shots. The correction process was done in about 4 1/2 - 5 hours and topped off with 2 coats of Swissvax Shield! and some After pics: The front clip was the only spot on the car that had clear film Thanks for viewing and if you would like to see a few more pics from the detail... (not many) you can find them HERE This will be me next write-up as it is a car I am working on currantly! Volvo C70 Again, Thanks for checking out my work!! Wishing all the Best, Brian
