Anyone use 4" pads with a FLEX XC3401 VRG"
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Kaban, Dec 27, 2010.
  1. Kaban
    Kaban Welcome to Detailing
    Just wondering, is it possible to use 4" pads with a FLEX XC3401 VRG? Have any of you tried this? How did you manage it?
  2. rwisejr
    rwisejr DB Forum Supporter
    There is or was only one way to to do this. That would be with the edge adapter . But i'm not sure its even available anymore. Most folk use a PC for the hard to reach areas.
  3. wascallyrabbit
    wascallyrabbit Virgin Detailer
    3m bought the edge adapter. its on the 3m website.
  4. rwisejr
    I have one of the first . But when was the last time you saw it? As last I heard it was unavailable.
  5. Trents_goat5.7
    Trents_goat5.7 Jedi Nuba
    AG still sells an edge adapter.
  6. tdekany
    tdekany Wax on..Wax off
    I use a 3" or 4" pad without an adapter. Just center it on the backing plate. Have been doing it for years.
  7. domino
    domino Welcome to Detailing
    so you guys are saying with an adaptor you can use 4" pads with a 3-4" backing plate on a flex?
    that has been the sole reason i havent picked up one of these machines
    can someone post a pic of the flex set up with the adaptor and 4" pad?
    do you have to use the edge pads? or can you use hook and loop LC pads?
  8. rwisejr
    You can only use the edge pads with this adapter. AG has had it on back order for sometime now . So I assume its no longer being made or they are re-designing it.
    YouTube - Me changing over a flex in seconds
  9. domino
    ahhh forget that then
    there is no way im polishing my car with that massive metal knob in the middle of the pad
  10. rfinkle2
    rfinkle2 DB Forum Supporter
    imo, the flex is somewhat violent compared to the pc, griots ro and the rotary. I rarely even use mine anymore due to limited pad size selection and it "forced rotation".
  11. Trents_goat5.7
  12. Trents_goat5.7
    The edge pads have a plate in the middle of the pads, that make it virtually impossible for the adapter to reach your paint.
  13. rwisejr
    So true I have never had an issue with the edge pad adapters touching .
  14. rwisejr
  15. Trents_goat5.7
    Yeah, I read that. I am just looking into different options as I just got my Flex. I may or may not pick it up, as I can easily change to smaller pads with my PC.
  16. rwisejr
    What I do Is have a PC setup for 4 in pads
  17. Trents_goat5.7
    More than likely what I will end up doing.
  18. Bunky
    Bunky Guest
    Me too. I usually keep a 3.75-in BP on it unless I switch to a 5-in if I use paint cleaner. I did not like the flex with paint cleaners...seems like overkill.
  19. DJ_JonnyV
    DJ_JonnyV DB Forum Supporter
    I use anything from a 5" to a 6.5" pad on my 3401. I was fortunate to get one of the "just" over 5" BPs when these babies first hit the market and they had a couple of re-designs of the BP on them.
  20. dschia
    dschia Jedi Nuba
    Is there any adaptor out there that can connect the edge adaptor with standard book and loop backing plate?
