Anyone use 3m green cut pads?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Car Connoisseur, Mar 26, 2010.
  1. Car Connoisseur
    Car Connoisseur Virgin Detailer
    How do they compare to lc cyan, or uber yellow pads used w/ rotary?
  2. d00t
    d00t Welcome to Detailing
    I use them with almost every detail. Haven't tried the LC Cyan, and only the Uber yellow a coupe of times.
    But I will say they cut fast and HOT. Be very careful with panel temps as the way the pads are cut (the thickness) and the PPI of the pad itself make it a very agressive pad. Easy to heat up the paint just a bit too much and twist it, or go right through!
    They have a bit of a learning curve, and are very stiff when starting out. But once they get some heat in them, they work like magic. I love them to death.
  3. Car Connoisseur
    Thanks for your feed back.Where in the U.S. do you buy 3m green pads and how much do they cost aprox?
  4. Carn
    Carn Welcome to Detailing
    The 3M pads in general rock. As doot mentioned the green pad is quite firm and can generate some heat so be careful (as always) when using them :thumb:
  5. Car Connoisseur
    Can I buy them in U.S.?
  6. agpatel
    agpatel OD On Detailing
    Nope, will have to order from the UK.
