Applied Supernatural. Drove car for 2 weeks. Washed with Prima Mystique. (Prima does not remove wax.) Attempt to apply p21s, will not spread on the paint. Streaks and does not evenly cover the surface what so ever. Spray Menzerna Top Inspection on another part of the car to remove the SN Re-try to apply p21s on TI cleaned part, spreads and covers no problem. It seems as though SN will not let you apply a different wax over it. I can add a layer of SN on top of the first no problem, but it will not let another brand layer. Make sense? Someone want to give it a shot and see if I am the only one? :shrug:
I am not an expert, but it might be the P21s. Were you applying it to a hot surface at all? I didn't listen to them and did it on a hot surface because I didn't have any cover and had streaking problems, but I blame that on myself. P21s is usually a good topper though.
Surface was cold, it was not the p21s. Once the Supernatural was removed, the p21s had no problems spreading.
Will Top Inspection remove a cured layer of wax? I'm just wondering how well your car shampoo actually cleaned the car. At least where I live, we have had a terrible time with pollen this spring. Pollen loves to grab into carnauba wax. Is it possible that your washing did not in fact remove all the pollen and that it was the remaining pollen on the surface that made it difficult for you to smoothly apply the P21S? Perhaps the Top Inspection did not remove the Supernatural but simply the remaining pollen. Just a thought.
Huh. I think SN looks good enough on it's own. Maybe it's too snobbish to let P21S onto the paint with it?
p21s is easier to apply and remove plus gives the same look as SN. For a daily driven car it does not make sense for me to waste my time with SN. Especially now that it does not like another wax bonding with it. Im 100% sure the shampoo cleaned the car well. Polen has not started here yet anyways.
so long as the car was dried thoroughly there shouldnt of been an issue. ive used supernatural and 2 weeks on topped it up with dodo rubbish boys edition and it was fine. ive never come across waxes counter acting with each other only strengthening and eepening the finish:shead:
