Another homemade wax thread....African style
Discussion in 'Detailing Bliss Lounge' started by Carn, Aug 28, 2008.
  1. Carn
    Carn Welcome to Detailing
    Firstly, seeing Cyclo's post gave me a bit more confidence to post about my own wax making adventures I recently started on and second this thread is in no way meant to steal your thunder Cyclo...just thought I'd share my experiences as well ;)
    I too found lots of useful information both in Ben's Rubbish Boys thread over on DW as well as from Dom himself. I only cooked up my 1st batch last night after trying to find many of the ingredients...some of them are hard to come by in small quantities over here (> 25kg) and some of them are still on their way. Regardless of some of the missing ingredients, I really wanted to get started so I began with the recipies I had ingredients for.
    First up some equipment I procured from the local supermarket. Didn't want to have issues with the wife if I happened to destroy her cookware and kitchen utensils :fs:
    Trays for the samples
    And some measuring cups
    Other equipment used not shown is a kitchen scale, some glasses, pots and an electric frying pan.
    Next up the ingredients, in no particular order
    Bees wax
    Montan wax
    Candelilla wax
    The infamous carnauba wax :worship2:
    And finally Coconut Oil and Paraffin
    Ingredients I am still waiting for include some other bees wax, orange oil or limonene I think it is also known as.
    With the ingredients out of the way my next mission was trying to find out how best to cook this stuff. Thankfully I had Dom and a few other guys share some tips and safety precautions with me so as to not burn down the house in the process.
    From what I have found there is literally so many aspects involved in order to control the final outcome of the finished product. Cooking times, cooling times, ingredients and ratios, quality of the ingredients, order of ingredients, etc, it is no wonder most of this stuff is made in a lab and whilst not strictly high tech it is no wonder there is only so far a person can go at home over the stove. That being said however I don't mean to take anything away from the guys who have successfully made homebrewed waxes, with enough time, patience and determination anything is indeed possible.
    Right, on to the actual cooking bit...From my initial research it seemed that the way to cook this was in a glass jar in a pot of boiling water on the stove so thats where I started. Whilst this method worked it was taking forever, I think I may have used to small a glass (a larger glass would have maximized the surface area lower down closer to the heat and possibly sped things up) or too small a pot of water.
    Before getting on to how I made the other 2 of the 3 initial samples I want to share one other aspect that tickled my curiosity. From reading various bits and pieces all over the general concensus was to let the finished mixture cool on it own. Ben's original thread on DW pointed out that sometimes the waxes were crystally (don't think thats a word but anyways) so I wondered if cooling them gradually as opposed to tossing them out into cold pans might make a small difference.
    With that in mind while I was preparing the first one on the stove I put the tray into the electric frying pan with some water to get that up to temperature for pouring the waxes into once melted on the stove. Needless to say I think the heat of the steel tray in the boiling water was ideal and after pouring the 1st finished wax into the tray we decided to make all of the others directly in the tray as opposed to in the pot on the stove. This seemed to work alot better and also avoided the transfer process which I was concerned about (hot wax and soft skin don't mix :yikes: )
    So onto the actual samples that were made. 3 Mixes were made varying only 1 ingredient at a time to see what effect they had on the finished product.
    Mix 4 was as follows :
    30g Carnauba wax
    10g Bees wax
    30g Coconut oil
    30ml paraffin
    Mix 2 was as follows :
    30g Carnauba wax
    10g Candellila wax
    30g Coconut oil
    30ml paraffin
    And the final mix
    30g Carnauba wax
    10g Montan wax
    30g Coconut oil
    30ml paraffin
    The really interesting part after all of this is how carnauba percentages are calculated in the real world. If we took the % carnauba by volume of the actual waxes in the product then these were all 75% carnauba by volume. If we took the % of volume excluding the solvent carrier it would be 43% carnauba by volume and finally if we took the % of total volume then they are roughly 30% carnauba by volume. Now I am no scientist but these 3 samples are all pretty hard which leads me to believe I either need to add more of the carrier oils/solvents or less carnuaba to make them softer. I think this possibly highlights and sheds light on Dom's initial claims in the Rubbish Boy thread that carnauba percentages are misleading, confusing and maybe all together bogus. Now I am not saying it can't be done, rather that in future I will not look at carnauba percentages in the same way. With that out of the way on to the actual samples again.
    All of the above mixes seem slightly too hard although they do melt quite nicely (except for the montan mix) when rubbed between your fingers, spread quite easily and go a long way and also buff off nicely. Interestingly as well they don't seem to be so crystally as I imagined, maybe a result of the gradual cooling process or maybe simply the way it is. As a result of the paraffin none of them smell too fantastic but that will hopefully change when some of the other ingredients arrive. As far as testing goes I stole a page out of Ben from Rubbish Boys book so to speak and used cd's. The initial testing on the cd's didn't really prove very much, all 3 seemed very similar in apperance to a control cd with no wax as well as one coated with a layer of CG's XXX paste wax. Water beading and sheeting seemed fairly consistent between all 5 as well so I don't think this is the best method of testing the products at the moment.
    Thats basically it for the moment, I will post some more pics and experiences later when I have recieved the other ingredients and made another batch. Overall this has been a really fun experiment and I have a new found respect for the guys and gals cooking these waxes up in a lab someplace :applause:
    Big thanks to Ben for his thread on DW and Dom in particular for sharing some of his knowledge on the subject with me :worship2:
  2. Dannyk
    Dannyk Jedi Nuba
    Wow, pretty neat. Things are really boiling now with these recipes , very interesting. Good Luck. Its interesting also with the oder issue, nothing has been said about the original oder when being processed. I guess thats why something is added to mask the original oder? Thanks.
  3. Cyclo
    Cyclo Birth of a Detailer
    The only original odor I have is from the beeswax, and it smells like ... honey.
  4. pirex
    pirex DB Certified Dealer
    Watermelon would smell GOOD! Just like Divine :D
  5. Carn
    We tried vanilla essence in one of them but it is obviously not oil soluble as we found out last night. There are lots of aroma type oils one could add for fragrance but we will have to see how they smell after we try the new ingredients before resorting to that ;)
  6. Rubbish Boy
    Rubbish Boy DB Certified Dealer
    Blimey you're all at it now!
    I chose CD's to test with mainly to check that it would spread and buff and not cause damage doing so. To check for looks and beading etc, then there is only one way I'm afraid and that's real paint and bodywork.
    Controlling the heat up is very hard in the home lab, but I don't think there is too much issue here unless, like I said on cyclo's thread, you are using powdered micronised carnauba. Cool down though can make a huge difference to texture. Not only temperature but also what you do to it as in stirring etc. One of the nicest texture waxes I have made involved a very complicated cooling process that would be nigh impossible to implement in a home lab style production run and nigh on impossible for me to be bothered to do it for more than a couple of jars of wax.
    And I think, like me, you have discovered pretty quickly that carnauba percent claims suck, in fact I think you could make a lot nicer wax without any carnauba at all. Still if you measure your carnauba percent using the unmelted flakes in relation to the final ml of wax it would probably be a bit closer to what some manufacturers claim.
  7. Carn
    Sorry Ben, once the bug bites you know how it goes. I think I am somewhat like you (I don't know you personally so no offence) in that I like to see and know how things work and why. I was also really intrigued as to whether or not I could actually make something useable in the kitchen :applause2:
    Don't mean to take anything away from the guys like yourself that have invested alot of time and money into doing what you do ;)
    I figured as much based on my 1st trials. They all went on quite nicely and actually a very little went a long long way. In terms of buffing them off again they all seemed very similar. The montan wax mix however seemed to be the most gummy if I could put it like that.
    That was some of my thinking when putting the pan into the hot water. The idea was to try and control how slowly it sets by reducing the heat in the pan (and hence the water) as well as the fact that the water would cool slower than the pan would have in the open air. They all seemed to be nice and smooth with only minimal graininess to them.
    Just looking at some of the numbers presented by manufacturers makes me wonder after last nights experiments. I won't for a second flat out state they hogwash because I am not a chemist and do not have access to any of the very high tech equipment or extensive scientific knowledge they may have. What does strike me however is that there is only so much carnauba one can put into a wax. In it's natural state it is rock hard and useless as a car wax IMHO. Definately more to it than the simple carnauba content people are fixated with.
    Thanks again for all the input Ben, your knowledge and advice has been invaluable in getting me started. Much appreciated :mounty:
  8. P1et
    This is so great, well done! I'd love to see the application process, the removal and the beading. Also, durability would be fantastic to see.
  9. DanPonjican
    DanPonjican Birth of a Detailer
    Subscribing!
  10. Buddy
    Way to go. sounds like you know exactly what you are doing. :worship2:
  11. DetailAddict
    DetailAddict Two Bucket System Washer
    Subscribing.. :)
  12. Denzil
    Man, after reading all these homemade wax threads I kind of want to create something of my own. Of course I don't have any knowledge of making waxes whatsoever but I sure would enjoy learning and experimenting with waxes.
  13. joep
    joep Welcome to Detailing
    definately a cool thread keep us updated
  14. joep
    after reading a few wax threads today i'm thinking about making my own wax ..
    i'm gonna make a wax...call it the Soprano wax....easy on ..bump u off...lol....
  15. Carn
    Well I fiddled around with the recipe a bit a few days ago and this is the fruits of my labour...
    Decided to make smaller samples until I can get something close to workable instead of possibly wasting all the ingredients on useless formula's that don't work.
    This recipe is really nice, the best one so far. I replaced the paraffin solvent with a natural alternative so it smells better and decreased the carnauba content slightly to make it more workable. The resulting sample is really nice, alot softer than the 1st batch and applies alot more evenly and with less need for heat to be built up to get it to flow. The one area this one is lacking in is hazing before buffing, I have since learnt (courtesy of Dom) that there are some other ingredients required to address that aspect of the wax.
    I have now gotten some other goodies to add and will be making up another batch this coming weekend....Wish me luck ;)
  16. Denzil
    Hehe, thanks for the update Carn!
  17. blucpe
    blucpe Birth of a Detailer
    you, good one you. lol.:applause:
  18. Carn
    So tonight I had some time to kill so I decided to get stuck into making some wax again. I have had some new ingredients laying around for a few weeks but haven't gotten around to playing with them until earlier this evening.
    Basically I tried 3 variations of my past favourite sample with some of the new ingredients and have found one I really like! All are around 27% carnauba by total volume and around 80% carnauba by wax volume. One of the aspect of the previous batches I wasn't happy with was the product hazing and drying prior to buffing, they all seemed to remain oily. I am happy to report that I have finally gotten a formula that hazes and dries quite quickly and also buffs off fairly easily if spread evenly :applause2:
    Some quick snaps...
    Formula A (My favourite of the 3)
    Formula B
    Formula C
    Some of the extra goodies I got included some oil based dye's which as you can see work pretty well :applause2:
    Tomorrow I will test them properly on the wife's car and take some snaps of the finish, beading, ect :thumb:
  19. P1et
    Very cool how it's different colors.
    But let's see it on your paint and I want to see the beading!
  20. DetailAddict
    cool colors.. :D
