Air Vantage 6"
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by advs1, Oct 7, 2008.
  1. advs1
    advs1 DB Forum Supporter
    ok so i think i am going to get the air vantage sander, since they are located 5 mins from me. But i went to a local paint store to find out about trizak 3m pads, the guy behind the counter gives me a price of $90 for 15 pads?!! My question is, what can i use that will be comparable to the 3m pads but not hurt the wallet so much? keep in mind i have no experience with air sanders or products associated with them. all my sanding has been done by hand.
  2. Buddy
    Do you have an air compressor that will handle all the cfm's that the sander will need. Those sanders are very demanding. some of them are up there @ 10 cfm cubic feet per minute.Just so you know most common air tools are @ 4 to 5 cfm's.:thumb:
  3. yukonon22
    yukonon22 Wax on..Wax off
    i thought my compressor could handle mine and it can't. really check that out .
  4. Denzil
    Hmm, any ideas on which compressors can handle the Air Vantage?
  5. JohnyB
    JohnyB Birth of a Detailer
  6. advs1
    wow i'll have to look into that. i have a pretty big compressor and the guy at air vantage said the new model only flows 3.3 cfm at 90psi??
  7. advs1
    so by that statement are you saying you are willing to send me you air vantage sander for half price?
    :applause2:
  8. Buddy
    3.3 cfm is very impressive for a sander of that type. You're looking very good. Glad this worked out for you. Every time some says something like that I need to barge in so they don't waste there money...:thumb:
  9. Reflect
    Is air sanding safer than regular hand sanding? It still scares me a little bit.
  10. MWAUTOPRO
    MWAUTOPRO Jedi Nuba
    In my limited experience, it is leaps and bounds safer, more consistent, and creates less of a risk of deep sanding marks being left behind. I would venture to say it is even safer then heavy compounding in terms of film build removal and heat build up.
  11. Duratys
    Duratys Welcome to Detailing
    What more of an excuse do you need to get a bigger compressor now :headbang:
    Its a mistake often made.
  12. advs1
    i appreciate the help. i just need to get over there this week. then i'll need to get some discs :yikes: but @ $100 for 15 only they well paying customers will get the trizac
