Aio question????????
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by THE ONE, Dec 7, 2008.
  1. THE ONE
    THE ONE Birth of a Detailer
    :graduation:WHAT IS A GOOD AIO? AND HOW MUCH CORRECTION CAN AN AIO DO?
  2. Cleaning Fool
    Cleaning Fool Birth of a Detailer
    Optimum Polyseal, Klasse AIO, Zaino AIO, just to name a few. These products are used mainly to remove oxidation and deep clean the paint and in leave some protection behind. Correction abilities will be small at best, Polyseal probobly has the most cut of any AIO Ive tried
  3. RamSus
    RamSus Jedi Nuba
    I used Poli-Seal & it did a decent job for me.
  4. DG 501
    DG 501 Jedi Nuba
    DG 501 is my favorite! It has awesome cleaning ability! If you mix it in with your compound, it will reduce the cut... but the cleaning properties....... PRODUCE KICK A** RESULTS!
    ESPECIALLY on white!
  5. Buddy
    Way to go DG 501. Great example. I guess you showed us...:thumb:
  6. JLs Detailing
    DG 501 for deep cleaning paint and leaving protection but if you want some correction too (and like Cleaningfool said it will be minimal) I like Megs D151. I didn't care for Poli-seal at all, but XMT 360 isn't bad. Oh I also like Zaino AIO, as it works very well and does some correction.
  7. Cleaning Fool
    So even tho this product says its for RV/Fiberglass/gel coats, you have no issues on clearcoated paint? Thw white looks great by the way!
  8. Dust2Glory
    Dust2Glory Nuba Guru
    I really like Poorboys Polish w/sealant. I would par it with DG501, 501 may clean a little better, but I think PwS has more protection
    Most if not all AIO's won't correct much of anything, it will fill it in before it actually corrects it
  9. blk45
    blk45 Jedi Nuba
    Is that dirt?
    I think we know you like 501, going by your screen name! :D
    It is a great product.
  10. Al-53
    Al-53 Welcome to Detailing
    DG 501 is a sealant/cleaner type product...it is paint safe and has great durability..it is made for marine use and it made to uphold constant water abrasion...
    Now to have it protect and Correct..I mix in some Po106 or SIP with the DG 501...depending on the correction needed....
    I use the mix first to do the corrections...and add some protection..then after I do the straight 501 for the protection and cleaning....I have had 501 last 5-6 months so far...with NO toppers...just a wash....this is one on my gallon products...
    Testimonial ....I did a friends boat in early May with 501....we pulled it in late Oct...no scum line and after just wash after the boat was out the side hull sheeted off the water..the top cutty and pilot house beaded like crazy,....this boat stays in the water 24/7..it is 34 feet long...lol....
    501 is a super sealant to me...I test the sh!t out of DG stuff to see what it really has...and its proved it self to me....great products..cheap money....
    Take your best sealant and try it on a boat in the water 24/7..and fished daily...see your results
    it is on our Honda CRV now since June...and looks like it did then...and beads like crazy....and on my truck since August...same thing....it will hit the spring mark I am sure of....
    Al
  11. Buddy
    Al-53, You really have DG down pat. I liked your write up. It was rather interesting...:thumb:
