AF's Tough Coat question
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by Alex1389, Jun 18, 2013.
  1. Alex1389
    Alex1389 Two Bucket System Washer
    Just wondering if AF's Tough Coat can be or would you seen any benefits of topping it with Illusion?
  2. kaiten408
    kaiten408 Jedi Nuba
    You should have no problem topping it with that. It'll help the Tough Coat last longer and IMO a nice carnauba gives the car a nicer finish.
  3. Alex1389
    Awesome, I've tried searching but haven't found information on topping tough coat with a canubra wax
  4. Holden
    Holden DB Forum Supporter
    Yes tough coat can be topped with a wax no problem. You can even put tough coat over auto finesse's tripple (which contains wax in it). I wouldn't go topping it over other waxes though, this combo alone is tried and tested to work by auto finesse themselves and I have tried this combo with excellent results. If you are sticking with auto finesse I would do one of the two following combo's since you have tough coat and illusion:
    AF Tough Prep ----> AF Tough Coat (2 coats) ----> AF Illusion
    or
    AF Tripple ----> AF Tough Coat (2 coats) ----> AF Illusion
  5. Alex1389
    Sweet, I have some paint correcting to complete first (FG400 megs M/F pad, SF4000) then I'll go with the Tough Coat - Illusion route. Now all I need is to order some Illusion :) Thanks for the help !!!!
