Adam's Products To ?
Discussion in 'Car Detailing Product Discussion' started by DP 08 GXP, Aug 9, 2012.
  1. DP 08 GXP
    DP 08 GXP Any Rag Vehicle Washer
    This is my 2nd year of detailing as a side business and I have at least doubled my customers from the previous year. Every open date I have filled and am booked until the middle of September so I've been pretty busy. My arsenal right now is pretty much all Adam's products. While they are all great products I am looking to get a little more cost effective while still working as well or even better. These are the products I am looking for your input on for substitutes that are cheaper and work well
    Adams APC: I've been looking at Meguiars APC plus and Super Degreaser. Thoughts?
    Adams Carpet and Upholstery Cleaner: Saw Meguiars APC (green bottle) had some good reviews. Thoughts?
    Adams Leather and Interior Cleaner: Same as above. Thoughts?
    Adams Green Wheel Cleaner: Open at this point.
    Adams Machine Super Sealant: Open to anything that lasts.
    Adams Americana: Open to anything that adds great depth and shine.
    Adams Invisible Undercarriage Spray: Open at this point.
    Adams SVRT. Looked at Meguiars Hyper for ability to dilute. Thoughts?
    Looking for any input you may have. Thanks!
  2. boredstudent3
    boredstudent3 Wax on..Wax off
    Adam's definitely has some gems in the line up.
    i would keep CUC, Invisible spray, and Super VRT.
    the rest can be substituted for something else. see above.
  3. Pureshine
    Pureshine DB Pro Supporter
    The only thing I say is don' t limit your self to one product. I use lots of other products cuase it's not one product for every car.
    Black wow is great for trim
    menzerna power lock sealant is great.
    Sonax wheel cleaner is great.
    Swissvax tire dressing is great a bit $$$.
    Leather master is good to.
    Sonax leather foam is good used last weekend works great.
    Todd
  4. DP 08 GXP
    thanks for the input...anybody else wanna chime in?
  5. tpr676
    tpr676 Any Rag Vehicle Washer
    I also work the weekends, I stopped buying adams way over priced I use products from California.
  6. LukeF
    LukeF Any Rag Vehicle Washer
    Yikes, although they can perform well, they [exclusively] would have no place in my detailing lineup if I wanted to make money.
    I have nothing against Adam's products, I actually come back to a few. However, purchasing some Megs detailers line products [APC, Dressing] will last you a long time when diluted. Optimum products are also affordable and ahead of the game as well.
  7. DP 08 GXP
    while i have the thread going...what are your thoughts on Adams Detail Spray and Waterless Wash?
  8. Meticulous-Detail
    Go with Megs APC+ or Optimum Power Clean
    Megs APC+ again or Folex
    Megs APC+ again but not for leather. I use either (from Detailers Line) Megs Leather cleaner and conditioner, Megs leather cleaner or Ultima Interior Shampoo Gel (expensive). OPC works well on leather too. PERL is also a versatile product for the interior.
    Most will say Sonax FE, but too expensive for my taste and there are less expensive products that do the job just as well. Megs All Wheel and Tire Cleaner works very well, Royal Brown is another good choice.
    Duragloss 105 for a straight sealant or Duragloss 501 for a paint cleaner sealant
    Collonite, inexpensive waxes with great durability 915, 476s and 845 all great choices. Top DG 105 or 501 with one of these and the protection will last a long time.
    No suggestions
    I have compared Megs ASD to Adams SVRT on the same car on opposite sides and the look and longevity was the same. The biggest difference is the price. I would use ASD on tires, exterior trim and wells and Hyper diluted on the interior. Megs Water Based Dressing also works well and can be diluted to adjust shine and gloss just like Hyper. PERL is also a good product.
    Note: All these suggestions are less expensive alternatives that will give you equal results. Yes there are better products out there, but you have to cater to your demographics and clientele. If you are doing high end exotics and charging accordingly I probably would chose different products, but for daily drivers the products mentioned above will not disappoint or break the bank.
    I had many of the Adams products you mentioned plus more and either returned them to Adams for an exchange of their towels and applicators (which I love) or traded my buddies for other products.
  9. Meticulous-Detail
    Megs Last Touch diluted 50/50 for clay and Ultima Waterless Wash Concentrate Plus
  10. LukeF
    I really like their Detail Spray to be honest because it is ready to use, smells good, and leaves the paint slick. It is very comparable, in my opinion, to Optimums Instant Detailer and Gloss Enhancer though. Smells good, easy to use [when diluted correctly], and leaves the paint slick. The OPT is $15 a gallon when diluted to the correct dilution and Adam's is $45 a gallon ready to use. Something else to consider, depending on what you use the DS spray [lube, wipedowns, drying aid, etc] is Optimum Car Wax. For $50 a gallon it is incredibly slick and can be used as a drying aid or a wax itself.
    I have used Adam's WW but none others so I can't really compare it to another brand. It is 3-4 times more expensive than Opticlean, which people have had good success with as a WW and Quick Detailer.
    If you haven't used Optimum No Rinse, I would seriously consider it for a Quick Detailer, Clay Lube, Rinseless Wash, Spot cleaner [bird bombs, bugs, etc], window cleaner, etc. Very economical and works well in most situations where it isn't necessary to use up a more expensive product.
  11. DP 08 GXP
    yeah i have Optimum No rinse on my shelf already...really liked the product when doing a no rinse wash...i havent tried it for other things like you mentioned so i will have to look into that.
    so far my cart has:
    Megs Super Degreaser and APC + to replace Adam's APC, Green Wheel Cleaner, and Carpet and Upholstery Cleaner
    Ultima Waterless Wash Concentrate to replace Adam's Waterless Wash
    Meguiars Hyper Dressing and Perl to see which one i like better to replace Adams SVRT
    I'll probably stick with Adam's Detail Spray (unless someone can sway me) and Leather and Interior Cleaner
    Waxes I was looking at Black Fire Wet Diamond but that does cost more then Adams MSS so im not sure if thats worth it
    most of my clients are farmers or family vehicles right now...live in a small farm town so it is what it is...im hoping to expand to the higher end world and with this only being my 2nd year im hoping it will happen next year
  12. LDM
    LDM Virgin Detailer
    Like mentioned above, for wax alternatives look into Collinite. I only have personal experience with the 845 but it's had excellent durability, and they say it's the least durable of the three. It's also easy to apply, cheap, and a little goes a long way.
  13. K3RMiTdot
    K3RMiTdot DB Forum Supporter
    Adams detail spray > diluted ONR for QD. i love ths slick surface it leaves behind like mentioned above. unless im diluting it wrong LOL
  14. LukeF
    I agree with that. OID and OCW are better for the price, but Adam's DS was done right. The newest version of ONR is fantastic though, definitely a lot slicker than the original version.
    For a wax or sealant, just go with FK1000P or a Collinite wax. If your customers are farmers and family they will appreciate the durability and looks and not care about the extra price for a little extra shine from BFWD [if there is any].
  15. 604_Snooze
    604_Snooze Obsessive Detailer
    For sealant, try collinite 845 for winter prep and Menz powerlock for summer prep.
    Quick sealant, Ultima paint guard plus or Optimum opti-seal
    Wax wise, try chemical guys butter wet wax. $35/gallon
    apc, try chemical guys nonsense, Colorless & Odorless. $30/gallon
    or Optimum power clean, can safely clean everywhere in/out of your car.
    dressing, just use Meg hyper dressing, perl or ultima trim/tire guard
    You have a DA? If yes, get a DA carpet brush for interior carpet/seat cleaning, it will save you a lot of time/energy.
  16. sprocketser
    sprocketser Virgin Detailer
    As for leather cleaners/protectants , either Leather Master or Leatherique also pretty good .
  17. DP 08 GXP
    ok lets talk car wash soap. what are your favorites?
  18. K3RMiTdot
    adams smells good... then again ive only used adams car wash soap.
  19. DP 08 GXP
    i think for the wheel cleaner i may go with Meg's Wheel Brightner...sounds like it has some good reviews and is strong enough to be diluted and still cut through baked on break dust
  20. Meticulous-Detail
    For maintenance washes Duragloss 901 or Majestic Solutions Ultra Gloss
    For a strong wash that will strip wax Chemical Guys Citrus Wash and Gloss
    Good choice, but be careful with WB you need to where PPE when using it. It is a strong acid based wheel cleaner and is not safe on all wheels. I wouldn’t only use it for caked on backed on stuff and have a non-acidic for well-maintained wheels.
