Adam's Green Wheel Cleaner
Discussion in 'Car Detailing Product Discussion' started by Dylan@Adams, Nov 10, 2010.
  1. Dylan@Adams
    Dylan@Adams Guest
    Adam's GREEN Wheel Cleaner is a 100% water-based cleaner that safely and effectively cleans tires and all types of wheels!
    Adam's GREEN Wheel Cleaner takes advantage of new breakthroughs in chemical engineering, creating a new class of non-ionic cleaner that does not release harmful zwitterions. Adam's GREEN Wheel Cleaner quickly and safely cleans tires and all types of wheels including clear coated, painted, aluminum, polished and anodized. The active ingredient in this cleaner was developed in America to replace the acids, butyl and butyl ethers found in most tire and wheel cleaning products, which have been proven harmful to both wheels and nature.
    It's an unfortunate fact that most wheel cleaners made and sold in America contain butyl or butyl ether. Although butyl is a highly effective cleaner, as well as inexpensive, it is harmful to man and the environment. Plus, butyl will white-stain aluminum and damage clear coated wheels and powder coating finishes. Butyl is also very harsh on your skin, causes respiratory distress when inhaled, and it is not readily biodegradable. It contains no butyl or petroleum distillates! Plus, our new GREEN Wheel Cleaner biodegrades 98% in less than 24 hours, protecting our surface waters from polluted storm drain runoff.
    BEFORE:
    [​IMG][​IMG]
    AFTER:
    [​IMG][​IMG]
    *special thanks to Jim (Nordgrey) for the great pictures.
  2. Emile
    Emile Welcome to Detailing
    Dylan, pH rating? Dilutable with water?
  3. Dylan@Adams
    Dylan@Adams Guest
    Dilatable with water, off the top of my head I don't know the pH, let me see if I can dig up the tech doc from the release. Working off my laptop today so I don't have all the info at my finger tips.
  4. Dylan@Adams
    Dylan@Adams Guest
    Back at the desk today!
    GWC has a pH of 10 at full strength, and drops towards 7.5 as you dilute it (water being 7.5) Its safe for most all wheel finishes at full strength and becomes relatively ineffective beyond a 50% dilution.
    Hope that helps.
