Adam's Detail Spray vs. Finish Kare 425
Discussion in 'Car Detailing Product Discussion' started by TWISTEDFRAME, Apr 3, 2010.
  1. TWISTEDFRAME
    TWISTEDFRAME Jedi Nuba
    I'm looking to try a new detail spray mainly for final wipe downs, not clay lube since I use ONR. I've tried all the OTC stuff and a few others (Wolfgang and DP) and heard good things about both of these. I would like to hear some opinions on the two, or any other suggestions. Thanks! :mounty:
  2. Cooter
    FK-425 or Optimum OID or Duragloss FC&S.
    You cant go wrong with FK425.
    There's a reason they sell so many gallons of that stuff.
  3. dsms
    dsms DB Forum Supporter
    Used both, personally I think both have their good and bad.
    Adams is easy to use, good shine
    FK is super slick, can get a bit streaky if the engine has been on or car is out in sun but leaves a great finish and the anti static make it a winner for me
    When doing a wipedown after a wash I use the 425 because it keeps the car dust free a little longer than Z6 or something like that.
    Both good products IMHO.
  4. christian900se
    FK 425 is one of the easiest quick detailers on the market. It leaves a great finish and although I was skeptical initially, does slightly decrease the amount of dust collected after driving. I highly recommend it; I have tried many QDs and this is one that I keep coming back to.
  5. cleanfiend
    cleanfiend Jedi Nuba
    OID is amazing stuff. and one 32 oz bottle makes 1 gallon of detail spray. the stuff smells great and leaves the surface feeling really slick. and the gloss is outstanding.
    although, sometimes ive found that it can get a little hazy when used on a hot surface and not totally wiped off, but it nothing that a second wipe or two cant fix
    Ive really been wanting to try out the adams detail spray, but i have so many detail sprays already that I dont really have any reason to.
  6. BigAl3
    BigAl3 Birth of a Detailer
    fk425 ftw...
  7. Chineseguy
    Chineseguy Birth of a Detailer
    If Fk425, then why not DG aquawax?
    If you're going to use it after a wash, I think a spray wax with carnauba inside would produce better protection...
  8. domino
    domino Welcome to Detailing
    FK425
    slickness is the best ive seen from a QD
  9. trhland
    trhland Nuba Guru
    alli use is Adams detail spray..its a great drying aid q/d i use this a ton in fact i just went to phils and picked up another gallon.. i should really look into the 5 gallon container. i go through this stuff loike water .....
  10. Pats300zx
    FK425 gets my vote. I do like Adams but I feel FK has a slight edge in slickness and gloss.
  11. supercharged
    both are great products, 425 has antistatic properties, but Adam's has a better scent to it.
  12. mrgolfrider
    My vote would have to go to FK425.
  13. TWISTEDFRAME
    Thanks for all the feedback guys! You have made up my mind....I'm going to order both...LOL
  14. Dust2Glory
    Dust2Glory Nuba Guru
    Try CG speed wipe
  15. trhland
    trhland Nuba Guru
    adams/ speed wipe same thing . is the best!!!!!! GREAT ON WINDOWS TOO!!
