Acura NSX Type R Replica, 27 hours- Premier Shine
Discussion in 'Show and Shine' started by premshine09, Mar 8, 2012.
  1. premshine09
    premshine09 Jedi Nuba
    Hello there DB,
    Over the last three days (27 hours total) I have had the opportunity to work on a 91 Acura NSX that has been converted and modified over many years into a Type R replica. The level of detail that went into the conversion is amazing. The car features a larger single turbo (T67) running low boost- 505 horses on the dyno.
    The owner has been a great client to work with and since last fall him and I have been discussing the process I would take to carry out the detail.
    The detail took 27 hours to complete over three days and him and I still have plans in the future (SV application) including an extremely thorough and regular maintenance schedule.
    On with the detail- prepare for major scroll
    Products/ tools used:
    Products:
    CG Maxi Sudz 2
    CG Citrus Wash and Clear
    Dawn Concentrate
    Sonax FE wheel cleaner
    Bleche White sidewall cleaner
    Megs APC
    Carpro Iron X
    Uber Fine Clay
    Leather Masters Suede/ Alcantara foam cleaner
    DI Aggressive Clay
    ONR
    Tarminator
    P21s Polishing Soap
    Eagle One Nevr Dull wadding
    Sonax Glass Cleaner
    Zaino Z12 Glass polish
    303 Aerospace Protectant
    Adams VRT dressing
    Folex Spot treatment
    Megs 105
    Menzerna Power Finish
    Menzerna Super Finish
    Menzerna 85rd
    IPA 30%
    Menzerna Powerlock
    CG JetSeal 109
    Tools:
    3 Wool wash mitts
    SV brushes- wheel, Pneu
    Uber Spoke wheel brush
    0000 steel whool
    Ridgid shopvac
    PC air compressor
    3000 grit paper
    Megs sanding block
    Flex DA
    PC DA
    Various backing plates
    Surbuf R series MF pads
    Uber Green foam
    Uber Orange foam
    Uber yellow foam
    Lake Country White foam
    LC 3 in. yellow foam
    LC 3 in. orange foam
    Total time- 27 hours over 3 days
    Wheels before:
    Headlight defects:
    Before: Under front hood and bay:
    The underside of the carbon fiber hood had some nice oxidization and defects...more on that later
    Visible Paint defects- swirling etc. viewable in sun
    EXTREMELY soft pillars before:
    Same soft paint found on roof, and spolier:
    Motor before:
    Exhaust system before: More on that later
    First up- motor cleaning
    ONR with a designated SV wheel brush used here
    Blown dry with the leaf blower as well as the air compressor
    Front end bay washed with ONR and Megs APC
    Sonax FE on the wheels
    The body was then pre-rinsed with ONR, left to dwell and then an application of Iron X was sprayed on around the entire exterior
    LSP still present- owner uses Zaino very often
    To strip- Dawn and CG Citrus wash and clear
    Two bucket method then carried out 3 times to clear as much LSP as possible
    There was considerable overspray on the door jambs that the owner had concerns about- Aggressive clay used here
    The car was then clayed with Uber fine clay using ONR as a lube and then re washed for the 3rd time- pulled inside to dry
    First thing to tackle- the water spotted and sad looking exhaust system
    After an hour and P21s soap:
    HELLO TURBO!
    Paint correction time- 1st and 2nd day- 20 hours total
    ****Spotting paint defects was easy to do by eye however my Nikon SLR had trouble- Apologies for no before and after paint correction pics******* the pearl white paint was tricky!
    Random sanding marks present
    The process:
    - add Surbuff R series pad to 105 as well
    The finish was compounded with Megs 105 and a yellow cutting pad or a Surbuff Pad via my Porter Cable. Finished down with Menzerna Power finish on an orange pad, finished down even more with Menzerna Super Finish (106fa) on a green pad and finally jeweled out with Menzerna 85rd- IPA wipedowns performed in-between each step of course.
    Coming along well
    Surbuff R series pads used on rear decklid as well as areas where sanding marks were present
    Spolier before:
    After:
    Driver side of spoiler:
    After:
    Spoiler coming along well:
    Thought this was a cool shot
    Tailights before:
    After:
    Rear bumper dialed in
    Correction coming along well
    The owners personal mechanic stopped by late that night to remove the wheels and put the car up on stands so that I could access the wheels more in depth and the wheel wells and coils too.
    Iron X doing its thing on the barrels
    After letting dwell and agitated after 10 minutes, the wheels were rinsed and brought inside
    Multiple tar spots in barrel
    The tar spots were heated with a heat gun one at a time and treated with Tarminator- here is a shot of the tar melting
    Plastic razor blade used to pick and remove tar spots:
    After the barrels were dried I then clayed the barrels with my designated wheel clay
    Wheels dried and dialed in
    Jetseal 109 applied to wheels- barrel and face
    With the wheels off I could then focus on degreasing the Coils and various pieces in the wells:
    Before
    After
    Pillar Correction
    Mirror before
    Mirror after:
    The CF engine cover was swirled and was pretty dull- there were also too spots where some sort of scuffing/oxidation existed
    - one pass with Menzerna Power finish on a 3 inch yellow pad made quick work of the defects
    Before:
    After:
    Notice line up by window showing before and after polishing:
    Near the end of Day two and after 20 hours of paint correction I focused more on getting the door jambs which containted a significiant amount of paint overspray dialed in.
    Wetsanded with 3000 grit here, followed up by hand polishing and PC polishing with a yellow pad- Megs 105
    Paper sitting in bucket full of warm water for 15 min.
    [​IMG][​IMG]
    After:
    The Recaro buckets had suede inserts- these were removed- blown with compressed air and vacuumed with a brush attachment.
    Leather Masters suede/alcantara cleaner used here with a damp MF towel- left to dry overnight.
    Owner had requested the sticker from the window tint to be removed
    Heated on low heat with heat gun
    MF towel dampened with 3M adhesive remover left over sticker for 5 minutes removed and plastic razor blade used to tremove sticker
    Zaino Z12 clear view glass polish applied via Flex DA and a Uber orange foam pad
    Wheels wiped down after sealant hazed and waiting to be put back on the beast
    Brand new Black pad to apply sealant used on this one:
    Mechanic came back over at end of night 2 to put wheels back on
    In garage at end of night 2 letting Menzerna Powerlock to sit overnight:
    Day 3- wrapping up
    last bit of polishing to focus on was under front hood (remember hazed and scuffed CF before pics in beginning?)
    Before:
    During Polishing- notice left/ right split
    Right section after:
    Top portion after
    Left and right done
    303 protectant applied to all trim/ weatherstripping:
    before:
    Glass was cleaned inside and out with Sonax Glass cleaner, tires dressed with adams VRT dressing, interior vacuumed, mats shampooed and extracted and a quick Megs APC wipedown in interior.
    Trunk mat had loose strings around logo- not good.
    AND NOW THE AFTERS:
    Thanks for looking!
    - Dan K - Premier Shine
  2. Chas
    Chas DB Forum Supporter
    Jaw dropping detail, simply amazing work on an amazing car.
  3. Wheelz25
    Wheelz25 Jedi Nuba
    Nice job, especially like the shots of the carbon fiber polished...
    By any chance was this owner at one of Phil's open house bbq's? i swear i saw that car there.
  4. premshine09
    Most likely- I had met the owner a little more than a year ago and we had discussed event Phil had hosted- I'm sure he was there
  5. P1et
    You call that a detail? That's just a regular wash 'n wax in my book.
    Just joking, just joking: insane attention to detail. Quite impressive.
  6. HeavyD
    HeavyD DB Forum Supporter
    Damn very impressive Dan. That was an insane ammount of work. You knocked that one out of the park! Great work!
    Yup I saw that car at Phils BBQ last year as well, I have pics of it somewhere?
    Darren
  7. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    Awesome attention to detail!
  8. Jumbo Jet
    Jumbo Jet Jedi Nuba
    Amazing work, and beautiful car.
  9. Darkstar752
    Darkstar752 Horizon Detailing
    Great work! I remember that car from last year, glad to see it went into good hands. Here's a cell phone pic of it from the BBQ: [​IMG]
  10. Wheelz25
    Wheelz25 Jedi Nuba
    Ah now that I actually think about it Frank actually contacted me about doing the cars but he is a little further than I typically travel. Glad to see he got someone like you to take care of them. From what I recall you will be busy with a couple other of his BIG vehicles, that hummer peaking in the background of the one picture.
  11. premshine09
    You got that right!
  12. Frankastic
    Nice work Dan!! I remember this car also at DD BBQ 2010.. wow 2 years later ... and here we are
  13. Gale Force
    Gale Force Obsessive Detailer
    Awesome attention to detail. :thumb:
  14. SRT8Spartan
    SRT8Spartan DB Forum Supporter
    wow thats awesome, love the CF before/after pics and those white wheels all cleaned up.
  15. kakeuter
    kakeuter DB Forum Supporter
    Complete amazingness, by far the best looking NSX I've seen.
    -Kody-
  16. Auto Concierge
    You did all the things I like to do to a car on this job, great work and pics........"Tightness".
  17. slanguage
    great work and attention to detail.
    great write-up as well.
    I love the NSX, and this is no exception.
