Hai Friends, Do you know about 3M all purpose cleaner?How did it worked?I'll plan to buy this product next month. Thanks.
Sorry, I wish I could help you I've never used it before. If you are going to make a purchase next month that gives plenty of time to do some reading and research find out about other APC's There are just so many out there to choose from and they can get very exspensive. I'm sure that the guys can give you examples of what they use to try to keep the cost down and get you a great product at the same time...:thumb:
I've been told that the "Green Stuff" APC from Majestic Solutions works really well, aswell as the one from Duragloss. I have no personal experience with either though. Hope that helps a little :thumb: Edit: Price on the "Green Stuff" APC from MS is $11.95 for the gallon (unsure on shipping). Duragloss is $17.95 for the gallon (Flat shipping rate of $4.95, could pick up some other great stuff with it!)
I use Adam's (Adam's Polishes) APC. If you dillute it 50/50 with water, it will give a less aggressive and is fine to get on some paint. It works awesome on tires and rims. If you don't dillute it, it works even tougher and will knock dirt loose in seconds, I used it today and watched it work.
I use 3M's APC at work and its great. I can't remember the standard size, but I think it is a gallon and it is VERY concentrate. Stuff lasts forever depending on the ratio you dilute it at. Works great for the engine since it says it's an all purpose cleaner and degreaser.
I use Adam's APC. Great stuff. Some like simple green too -- I guess it depends on what you are trying to accomplish?
