Client wanted it cleaned up but not a full correction as it had a lot of RIDS. Decided to use some of the products I got from Kevin Brown The hood - Pretty much sums up the defects on the whole car with RIDS and swirls The fender Headlight lids 50/50 on the fender Sanding discs to cut those RIDS Rear bumper scuff Gone I had fun using those sanding discs. Pass fender After It received the same sanding treatment Leather seats cleaning 50/50 Done
Nice work man... This is the first time I have seen someone sanding the surface to remove rids... were they that bad that it needed sanding?
Thanks kaban. Several were like the ones on the roof. The discs were only 2500 and 3000 grit. I'll check if I used the 2000 grit. It cuts down on time and I had a lot of clear to work with. Easy to use and removes less clear overall than compounding per Kevin's advice.
