911fanatic vs 06M5
Discussion in 'Show and Shine' started by 911Fanatic, Nov 15, 2010.
  1. 911Fanatic
    Client had recently purchased this M5 down in the US and had a high end shop detail it before driving back to Canada. Once home, he had another shop wash it and induce some swirling. The original plan was for a single stage polish but after seeing the car, the swirling was minimal and we are heading into the winter so it was decided we would add a coat of Raceglaze Black Label and call it a day until the spring. We are heading into 6 months of cold, wet, snowy weather so polishing the car at this time of year would have been a waste of the clients money.
    Engine, jambs and trim were cleaned with test APC and RG Brushes
    Washed with CG CWC as we didn't want to strip the sealant already applied, but add to it.
    Wheels were, well, a mess. Tried our APC, Sonax, a mild acid and Aqurtz Iron Cut as well.
    LSP was Raceglaze Black Label Wax
    Tires were dressed with CG Silk Shine
    Leather was dressed with Raceglaze Leather Balm
    Exhaust tips were cleaned with P21S Polishing soap, polished with 0000 steel wool and AG Metal Polish and sealed with Blackfire All Metal Sealant
    Glass polished with AG Glass Polish via PC/White pad at speed 3
    Wheels sealed with Blackfire All Metal Sealant
    Total time - approx 8 hours
    The M5 upon arrival
    The wheels were quite dirty with a lot of brake dust and shipping wax? left from previous details.
    Some of the polish / sealant residue we found. Note the nasty key hole.
    More residue under the door handle...
    and along this door edge
    There was so much brake dust left from the previous detailing, we sprayed Iron Cut on the wheel for fun! WEEEEEEEEE!!
    Someone had used something VERY caustic on the wheels previous to me getting it.
    More damage.
    Nasty tips. These would require a wee bit of work to bring back but even then, they will require some work with a Dremel on its next visit.
    These wheels have already been cleaned with APC, then a mild acid and this is how much brake dust was still embedded in the wheels. Just sick.
    Seats were given some loving with Raceglaze Leather Balm
    Look! Even more residue.
    Black Label drying.
    Leaves the paint looking very wet. Nice.
    Applying the Black Label with a thin foam applicator. The thin pads seem to make it easier to get a nice thin layer of wax on. The RG is a softer wax so I'm going to put it in the fridge before I use it next to se if it'll harden up a bit.
    I noticed some spotting on the hood that we will try to remove when we polish it in the spring.
    The tips looking a little better.
    Buildup of dirt around around the M5 logo missed by last two shops. Q tips and a wee bit of prewax cleaner tidied it up.
    And finally, some afters.
    Doesn't seem to affect the flake at all. Flake pop was alive and well.
    Wheels looking a lot better. Sealed with Blackfire All Metal Sealant.
    Money shot.
    Thanks for looking.
  2. cnut
    cnut Guest
    Beautiful work! Those M5s are some sweet rides.
  3. JoeyZ
    JoeyZ Obsessive Detailer
    Nice work. I absolutely love that car.
  4. fricker66
    fricker66 Birth of a Detailer
    Nice work. Gotta love BMW brake dust...
  5. bryansbestwax
    i heard about this one, nice save, nice to show em how to really detail a car.
  6. P1et
    Really nice work Ken, that's a vehicle any man can be proud of.
  7. PDJ3.2
    PDJ3.2 Birth of a Detailer
    Ken, could you tell me the difference between the Sonax and Iron Cut? They seem pretty similar to me
  8. Carn
    Carn Welcome to Detailing
    Stunning...Last pic is my fave :thumb:
  9. 911Fanatic
    Sonax is a non acid wheel cleaner whereas the Aquartz Iron Cut is meant to be used on paint to remove industrial fallout from paint that clay doesn't remove. I used the Iron Cut on these wheels as there was soooooo much brake dust etched into the wheels that even a mild acid wouldn't remove.
  10. AutoObsessed
    AutoObsessed Dealers
    Great job Ken!
    Looks fantastic
  11. JoeyZ
    No....no you dont.
    LOL
  12. detailersdomain
  13. kakeuter
    kakeuter DB Forum Supporter
    The car came out awesome, nice work.
    -Kody-
  14. Upper Class Detailing
  15. Danny
    Danny Nuba Guru
    Great job
  16. slanguage
    Nice work Ken. Sexy car.
    Where can I get Iron Cut?
    Does it work better on the embedded brake dust than Sonax does?
  17. dsms
    dsms DB Forum Supporter
    Looks great Ken! Kinda nice not having to break your back and pull you hair out on a 20hr. correction all the time huh?
    Again nice work!
  18. 911Fanatic
    You can get it at autoaesthetica I believe. I used it on the wheels to remove the embedded brake dust that nothing else would. Sonax is just another non acid wheel cleaner. It is only going to do so much. For wheels, its much more economical to use something like Megs Wheel Brightener that can be diluted down to suit your needs. I would only use the Iron Cut on wheels in dire situations.
    You know it. I love this time of year as its pretty much all winter details like this. Wash, clay and 2 coats of protection. :)
  19. Auto Concierge
    So much for the "High end detail" in the states................ now the car is looking on point Ken!.
  20. detaildoc
    detaildoc Guest
    Awesome job as always Ken. Love the finish on those tires.
