79 Mercedes 450SL (Interior + Mold Abatement)
Discussion in 'Show and Shine' started by David Fermani, Oct 26, 2008.
  1. David Fermani
    I received a call from this client’s property manager after he noticed a disgusting mold contamination on the inside of this 1979 Mercedes 450SL. He tried having it cleaned by a local car-washer and not only was the results terrible, but the mold returned after a few weeks! I tried asking as many questions as possible to diagnosis the cause & origin of the contamination so I could plan ahead and create a game plan that would effectively tackle the project. The owner had no idea what this problem was caused from and/or how it got there. He explained that the vehicle was never involved in a flood and has never noticed any water inside at any time. The vehicle is parked at the owner’s vacation water front condo in Los Olas (FT. Lauderdale) inside their parking structure.
    This environment (dark & wet) is key for the development of a mold growth and if not properly treated, could literally destroy the interior of a vehicle at the same time infecting the health of its occupants. At 1st I researched multiple products that are designed for the removal of mold on leather. I also consulted several forum members (Grouse ~ Aaron @ 3LG) and he recommended cleaning the vehicle’s leather with products from Leather Master. I then called Phil from Detailer’s Domain and he put me in contact with Multimaster of North America (reseller of LeatherMaster). They specialize in all facets of cleaning, repairing and protecting leather as well as other surfaces including fabrics & wood. Many of their products of imported from Italy. I was instructed to 1st clean the leather and then treat with Mold Killer to prevent its return.
    Upon 1st inspection, I noticed a medium growth of mold spores contained mostly to the leather seats, armrest and steering wheel. There was also a slight dusty film of mold on the door trim panels and carpets.
    I 1st removed all possible carpet assemblies and removable trim pieces such as the package tray. At this point, I have no idea what created this mold problem and continued to search for signs of evidence. I began cleaning the seats with LeatherMaster’s Rapid Cleaner S. This product is recommended to be dispensed in a special foamer type sprayer nozzle and gets applied to a foam style sponge. To my surprise, this product safely & immediately removed the surface mold and cleaned the leather surfaces too.
    Here’s what the sponge water looked like after cleaning the leather:
    Leather/vinyl trim panels were also cleaned with Rapid S and all other panels were scrubbed clean via toothbrush with Auto Magic Special Cleaner.
    Carpets/Floor mats received a series of cleaning procedures that I’ve documented below:
    Each panel was dry scrubbed with a stiff brush. This looses up the debris and allows for a more effective cleaning. It also stands up the nape of the fabric because the deeply embedded debris gets loosened to clean deep into the piling strands of fabric.
    Next, the surface is vacuumed:
    Next the surface is blown out with compressed air to loosen up even more ground in debris:
    **These 2 steps alone are key for proper cleaning and can actually make or break certain fabric cleaning applications. It allows the ground in dirt & debris to be lifted away instead of buried in deeper while wet cleaning. It is essential to perform these 2 steps prior to getting any of the surfaces wet. **
    Next, all surfaces were pre-soaked & scrubbed with Auto Magic Enzyme Pre-Spot. This eats away and kills the bacteria in the fabric.
    Next I prepared a bucket mixed with 1 gallon of water and Auto Magic EZ-Clean HD shampoo & Mark-V’s Breeze Odor Eliminator.
    This was foamed up by sticking my compressed air nozzle in the bucket and then applied via Grout Sponge. Each floor matt was cleaned individually to prevent over saturation of the surface. I then scrubbed the foam into the fabric. The foam creates and allows the dirt to lift up and out.
    Next, I slowly vacuumed each surface:
    Next, all the remaining wetness, soiling & chemicals were toweled out:
    Floor mats and fabric panels were left outside in sunlight to speed up the final drying process. When 100% dry, they were dry brushed again to fluff up the fabric.
    Finally, all the leather was treated with Leathermasters Mold Cleaner in 2 separate applications.
    After cleaning the interior, I proceeded to wash the exterior with using the owner’s garden hose. While rinsing, I noticed the seals on the convertible hard top were leaky. Water was entering and running down the windows. I didn’t think anything of it, but as soon as I opened up doors and looked inside, I noticed multiple medium sized puddles on the center and rear floor pans and water was running down behind each ¼ panel interior trim panel!!!!!
    I finally realized and was able to confirm the cause of the problem. It seems as if every time the vehicle was washed and/or in the rain, water entered the cabin compartment. This in turn created a major mold growth after closing the doors for months and stored in the dark, damp parking structure. I informed the owner of this discovery and he was shocked and very happy. I was too, by knowing that what I did fixed the problem and discovered how to prevent it from occurring again. I also instructed the owner to leave the windows down for several days as well as the leave the vehicle outside so that the sun can dry up any remaining wetness.
    Unfortunately, due to a heavy rainstorm, I didn’t have the opportunity to take any outside final photos; just inside the garage. Here’s the final outcome.
  2. Buddy
    You're a brave man. You did a great job. That was pretty gross. I might have pressure washed the inside of the car .hahaha
  3. 911Fanatic
    Nice save! I was going to say, living on the "WET" coast, I have learned the only way you will get mould inside the car is moisture ,but you found that out. Great job.
  4. Denzil
    Wow, amazing recovery! Did you bother to rinse the floor mats? I can't imagine how much I would charge to do this health hazard, LoL.
  5. bentley147
    bentley147 Jedi Nuba
    i know u had pressure wash inside of the car ..that mold was crazy on there ....it had to be smelling shit in there too ...bottom line good job !!!!!!:gross:
  6. togwt
    Great turnaround on the interior David. I've treated / detailed a few interiors that had mould on the leather, but nothing as bad as that.
    Now that the cause has been fixed things should be fine, again great job
  7. Cooter
    WOW!! David you rock!
  8. David Fermani
    I would have loved to blast away this one!!
    Thanks! I guess I found it out the hard way?
    Thanks Denzil. Mercedes matts have a tendancy of falling apart if they get power washed. Especially 30 year old ones. I avoided getting them too wet.
    Believe it or not, the smell wasn't that bad. It kinda smelled like an old car, but alot stronger. :gross:
    Thanks Mr. Miller! :worship2:
    Thanks Cooter.
  9. virtual
    virtual DB Pro Supporter
    Nice work! :)
  10. Hum-Benz
    Hum-Benz Wax on..Wax off
    Great turnaround! Hope you wore a mask...you did didn't you?
  11. Denzil
    Ahh, thanks for the clarification David! That's definitely something I'll keep in mind when older vehicles come my way. :thumb:
  12. togwt
    You'd be amazed at how many people don't think this microscopic fungi presents a health risk
    :shead:
    "Moulds are ubiquitous in nature, and mould spores are a common component of household and workplace dust. However, when mould spores are present in large quantities, they can present a health hazard to humans, potentially causing allergic reactions and respiratory problems". Wikipedia
  13. GBS
    GBS Wax on..Wax off
    Mold on leather can be a problem in Florida but that was really bad. Great Job.
  14. Pats300zx
    Awesome job David..That thing was nasty :(
  15. Hum-Benz
    When I moved to North Carolina the apartment I got before I bought a home wound up having black mold. I didn't realize it until I had a severe asthma attack in which mold was the cause.
  16. Kron
    Kron Two Bucket System Washer
    Great care and attention on those mats, Really impressive work!
  17. joep
    joep Welcome to Detailing
    you put a lot of work in the interior and it shows,but i can't help wondering if their might be mold in the AC vents and duct work ..just curious
  18. slanguage
    Nice turn-around on that :gross: interior.
    I would have worn a decontamination suit on that job.
  19. Carn
    Carn Welcome to Detailing
    Terrific work, I would have donned a Haz Mat suit for that job :gross:
  20. scheerspeed
    WOW! incredible turnaround there david!
