3M, Sonus & PFW
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by MadOzodi, Sep 2, 2008.
  1. MadOzodi
    MadOzodi Nuba Guru
    I had a chance to use all three this weekend, all on my 3401. I really enjoyed using the PFW with SIP...until it got 10* hotter, at which point I had to switch to SysOneX3 + orange cross groove. The white Sonus pad was a bear to use with 106fa until the last section of my roof. 3M. UK black pad (from Nica) + 106fa on my hood was a dream...so smooth and effortless.
    Just wanted to share :peace:
  2. Brian N
    Brian N Jedi Nuba
    So did you like or dislike the Sonus? Sorry if I missed your opinion in your comment.
    Also what is UK Black equivalent to in terms of lake country pads? I would really like a nice finishing/jeweling pad.
    Thanks!
  3. D&D Auto Detailing
    CCS gray I believe.
  4. Brian N
    Brian N Jedi Nuba
    Thank you kindly good sir. :worship2:
  5. MadOzodi
    MadOzodi Nuba Guru
    Ya know, the UK black pad felt like it lost some of its bite after the first section and that may be why it ended up feeling so smooth.
    As far as the Sonus pad is concerned, I think it was just too hot for me to be using it with 106fa. Also, I'm thinking my prep may have also been insufficient; the Griot's clay wasn't removing what I was expecting it to remove and it would catch on spots that had plenty of ONR clay lube sprayed on the surface.
    I will say that I wouldn't mind trying a rotary and wool after using the PFW with the 3401; I could have used more correction ability on the spoiler outline I was trying to correct. I'll try to post up the pics after work.
  6. Nica
    I'm quite pleased with how the 3M UK pads have performed for me, it's really hard to describe the difference but when you use it an feel them for your self it's quite the pleasant experience.
    Look forward to the pictures :druling: and thank you for sharing :peace:
  7. Denzil
    Great to hear your experience there Ozzy!
  8. Brian N
    Brian N Jedi Nuba
    Bump for pictures.
    So does anybody know which is the 3M finishing pad Black or Blue? I know the orange is for cutting but I am confused on the pad aggressiveness order. From what I can tell from most to least aggressive it is Orange>Black>Blue?
  9. MadOzodi
    MadOzodi Nuba Guru
    Didn't get to the pics tonight, hopefully tomorrow.
  10. Denzil
    Yeah, orange, black, then blue from most aggressive to least aggressive for the 3M UK pads.
  11. Nica
    :nod: you got it Orange, Black and Blue...Blue 3M UK pad is one of my favorites to use with 85RD, works like champ :thumb:
  12. Brian N
    Brian N Jedi Nuba
    Very tempting Carlos. I may have to order some of these from you if you still have them available.
  13. Nica
    I believe I still have a few left, I'm quite pleased with 3M UK pads..but just my :2cents:
  14. MadOzodi
    MadOzodi Nuba Guru
    I really wish I'd tried the 3M UK pads earlier. IMO, they're the perfect size for the 3401.
  15. Brian N
    Brian N Jedi Nuba
    Hrmm.. not making this any easier for me now. :giggle:
    So they are all waffle pads correct? I have never used a waffle pad before, how is it different?
  16. makos1610
    makos1610 Two Bucket System Washer
    how can i order those pads?? What's the price??
  17. Denzil
    The orange pad and the Ultimate pads are the only pads that aren't of the waffle type.
  18. MadOzodi
    MadOzodi Nuba Guru
    Here are the pics. Keep in mind that my '00 Mustang GT had never been garage kept; apartment parking lot then my driveway. I was all sorts of :gross: when I removed the spoiler for the first time ever.
    Befores:
    Afters:
    The after pics might be a mix of pre and post 85RD passes...I can't remember. Anywho, the PFW and SIP was used on the driver's side 1/3 of the trunk. As I said before, it must've gotten too hot because I couldn't duplicate the results on the middle and passenger's side thirds of the trunk; after the SIP had flashed clear and I'd done a couple of Prep-All wipedowns, the paint wasn't as black.
    Sorry, no pics of the 106FA/Sonus/3M UK Black combos on the Mazdaspeed3.
  19. Denzil
    It looks a lot better than before Ozzy!
  20. MadOzodi
    MadOzodi Nuba Guru
    Thanks Denz...even with wetsanding and a rotary, I don't know how much more I could have done.
