2011 Kia Sportage *First detail*
Discussion in 'Show and Shine' started by min2patl, Sep 28, 2017.
  1. min2patl
    min2patl Virgin Detailer
    I detailed my friend’s car. This is the first detail I've ever done. I had to do this at my friend’s apartment complex with no running water/pressure washer, therefore I could not use my foam lance or anything of that sort. I spread out the work over a couple of days since she uses the car for work every day so some of the completed panels/trim/windows will look dusty in some of the pictures. Upon completion, I took the car to a self service pressure washer to remove the compound dust and wiped down the trim/windows.
    I apologize for the photos, I’m still learning on how to take the pictures so you can see the proper details and was more focused on the detail process than capturing pictures.
    Products used:
    Filtered water - filled in spray bottle
    Dawn soap and filtered water - filled in spray bottle
    Detailer
    Medium grade clay
    PC7424XP
    M105 with Uber orange foam pad
    M205 with Uber blue foam pad
    Trinova paint sealant with Uber black foam pad
    Trinova UV protectant trim dressing (did not take pictures of it applied)
    Fender before wipe
    Fender after wipe
    Fender after clay
    Fender after M105 & M205 [​IMG]
    Door before
    Door after M105 & M205
    Door after sealant
    Trunk before
    Trunk after M105 & M205
    Trunk after sealant
    Left rear before
    Left rear after clay
    Left rear after M105 & M205
    Rear quarter panel
    50/50 hood shot
    Hood after
    Side shot after sealant
    Final photo after wash (still needed to wipe down windows and clean/apply trim sealant)
  2. AndyThomason
    Great job especially considering the conditions you were forced to work in! Who knew that vehicle had such a nice metallic flake?!
    min2patl likes this.
